Router - frequent connection dropping
Chapworthy
Message 20 of 20
Hi, have been having issues with our broadband the last few weeks - connection from my router drops (WiFi and ethernet), usually a couple of times a day, and then requires a restart to restore connection. Any ideas?
Thanks in advance 🙂
19 REPLIES 19
Message 1 of 20
Hi Chapworthy
Ahh brilliant 🙂
If you do experience any further issues, then please let us know.
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 2 of 20
Yes! Connecting fine now, great stuff 😃 thank you
Message 3 of 20
Hi Chapworthy
Thank you 🙂
All updated, please can you retest?
Message 4 of 20
Hi Debbie,
Yes that's fine to do that now, thanks.
Message 5 of 20
Hi Chapworthy
In regards to the VPN, I will need to make a change to your router firmware, will it be ok if I do this now?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
Message 6 of 20
Hi Debbie,
We've received and installed the router, the connection seems fine at the moment, although I can no longer connect to my work VPN (which is required), is this something you can look at remotely?
Thanks, Chris
Message 7 of 20
Hi Chapworthy
Message 8 of 20
Thanks Debbie, yes please, if you think this could potentially help.
Message 9 of 20
Hi Chapworthy
Would you like me to send a replacement router for testing so we can rule this out?
Message 10 of 20
Hi Debbie, no I haven't been sent a new router for testing.
Message 11 of 20
Hi Chapworthy
Have we sent you a replacement router for testing?
Message 12 of 20
Hi Debbie,
Sorry for delay in my reply! The connection has been generally a lot better the last few days, although has dropped a couple of times, including this morning, although only for very short periods (I notice because my work VPN connection disconnects each time)
Message 13 of 20
Hi Chapworthy
I can see 1 reconnection. The line test is clear.
How has the connection been since your last post?
Message 14 of 20
Hi Chris, it just dropped now (has been working well for the last few days), I checked the openreach modem, the power light is on, internet is off, DSL and LAN are flashing.
Message 15 of 20
OK thanks. Next time you experience the problem could you check the Openreach modem lights to see if they've changed
Message 16 of 20
Hi Chris, not too sure - I think maybe the internet light goes off.  We had an issue on Sunday when the whole thing went down and needed a restart on the openreach modem too, but that seemed different to the everyday day issues.
Message 17 of 20
Hi Chapworthy,
Have you noticed if the lights change on the Openreach modem when the connection drops?
Message 18 of 20
Hi Michelle - no, it's a bit weird, router light stays continuous white. Also, sometimes it only affects certain devices whilst others keep a connection... Working fine right now btw
Anonymous User
Message 19 of 20
I'm sorry to hear this and I will take a look now. I've run a test on the line which hasn't detected a fault, however I can see re-connections on the line. Can I just confirm, do the lights change on the router or the Openreach modem when this happens please?
Anonymous User
