on 14-11-2021 08:07 AM
Hi, our router has stopped sending wifi further than about 1 metre. It started about 4 days ago, we have good speed to the router, and an engineer was here last month fitting a new socket and testing the line. If you are within 1 metre of it then the wifi connection and internet is as expected. But if you are more than 1 metre away that then it gets almost no signal. We have tried a factory reset (5 times) but this has not fixed it. We assume therefore there is a fault in the router and would like to get a replacement.
on 31-12-2021 07:18 AM
Hi Box Cottage
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this further.
on 30-12-2021 03:13 PM
If you still need help with WiFi coverage I can help a lot with this type of issue.
30-12-2021 12:13 PM - edited 30-12-2021 12:13 PM
@Box Cottage, you posted this under "billing".
It also didn't escalate into the workflow, so it has been overlooked.
Have you got this sorted out?
I'll move your thread to the Broadband section of the forum. If you still need help with this, please post back to let us know, and I will make sure that it gets into the queue for attention.
You will need to complete your community forum profile details for TT staff to identify your account.
Please go via your avatar/name; settings; launch profile wizard.
