Router still drops connection but white light suggests itis connected
Julian_C
Message 11 of 11
I constantly have Internet drop outs they requires me to re boot router 3 to 4 times a day, I raised 2nd December and was talked through a full reset but it is just getting worse?
10 REPLIES 10
Message 1 of 11
I've escalated this over to our Faults Escalation Team now and I'll post back here as soon as I receive an update. It's possible that the team may also try and contact you directly.
Message 2 of 11
Yes I added account number a few days ago
Message 3 of 11
Good afternoon,
Can I just confirm, are the details in your Community Profile correct?
Message 4 of 11
@Julian_C, at this time of the day and over weekends  / holidays support is from fellow members.
Staff are on here Monday to Friday from early breakfast time, but not into the evening.
I'll re-escalate this for staff attention. Please look out for their replies during the daytime.
Julian_C
Message 5 of 11
Is anyone from talk talk on the forum who can help or do we have to use the useless chat bots to get any response?
Message 6 of 11
Hi Debbie I have updated my info although I have used account no rather than phone number as the detail wasn't clear
Message 7 of 11
Hi @Julian_C
I can't be sure about the light on your extender, as I have no idea of the make & model of it. That is not the best way to extend WiFi coverage of this router, but there may well be an underlying issue to this.
Message 8 of 11
Hi Keith
My router is a talk talk Sagemcom FAST 5364
Package is Fibre65
No wired connections all are on WiFi.
To Answer Debbie's question the last noticible drop out was 8pm last night and this was the 4th of the day to that point and the lights remain solid and white on the front.
The drop offs are relatively short and some devices do auto reconnect but I have some important ones that will not reconnect without a manual switch off and on of the router power.
Because of the issues I have been having I have re ently added a wifi range extender which I only have one garage based inverter connected to this has a 2.4 ghz and a 5ghz light and it is notable that when I have the drop outs it is the lower 2.4ghz light that doest come back on (I assume the extra info may help although it didn't help within the 4 hour chat with talk talk support yesterday).
Message 9 of 11
Hi Julian_C
When did the connection last drop? Did the white light stay on the front of the router?
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 10 of 11
2. What package are you on?
3. If you have any wired connections, are they affected in the same way as wireless ones?
