Sagecom Fast 5364 Superhub Issue - Orange Flashing Light
katblue2022
Message 9 of 9
So here goes. Have been having an issue since 1AM this morning.
My Sagecom Superhub Dropped its internet connection and restarted which was not a big issue. But then when it restarted the router will no longer syncronize withn the fiber dsl in my home. i just get the orange flashing light and around 10 minutes after power cycling the router it will change to an orange and blue blink for a few seconds than go back to just orange.
I have done all the diagnostics possible with can find no issues the line test has come back fine and i have no issues with my internal cables.
i did see however that the firmware on my router seems to have been updated just geting so frustrated as i live in the middle of no where and rely on my broadband for alot of things.
any help would be much apreciated
8 REPLIES 8
Message 1 of 9
Hi katblue2022
I'm so glad to hear this, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
katblue2022
Message 2 of 9
Sorry for the delay in replying i have had the router and have installed it the issue with the synchronization is now sorted thank you.
much apreciated
Message 3 of 9
Hi katblue2022
Message 4 of 9
Hi katblue2022
Apologies again for this. The router is on its way, please allow 48hrs for this to arrive.
Please let us know once you have tested with the new router.
Thanks again.
katblue2022
Message 5 of 9
After the connection had not stabalized after half an hour i did indeed power cycle the router and then left it another half an hour after that when i still had not stabilized i did indeed factory reset the router. This has had no effect on the issue as i still get the same issue after following all the diagnostics suggested earlier when i was chating to an agent.
If a replacement router is the only option then will have to wait for that to arive and thank you for your help
Kind Regards
Message 6 of 9
Hi katblue2022
When the connection dropped around 1am, did you reboot the router or switch the router off?
We can't roll firmware back sorry. Have you tried factory resetting the router using the pin hole reset for ten seconds?
katblue2022
Message 7 of 9
I would but would there be no way to just role back the firmware on my router as aside from the issue that has arrisen there seems to be no other issue anywhere. if a new router is required then that is acceptable but would prefer a solution that would allow for use of my services as soon as possible.
kind regards
Message 8 of 9
Hi katblue2022
I've completed a line test which hasn't detected any faults.
 I think we should send a replacement router. Would you like me to arrange this?
