on 24-08-2024 06:28 PM
Does anyone know the price of a Sagemcom FAST 266 through TT ?
on 27-08-2024 07:12 AM
Good morning,
Ok thank you for the update and please let us know how you get on with FTTP.
on 26-08-2024 05:31 PM
@des09, always reply in the thread.
Any notification emails you receive are from a No Reply address, so can't reach staff, or anyone else.
on 26-08-2024 04:24 PM
Thanks for getting back.
I've tried responding, but my first attempt doesn't appear to have arrived at all and my second attempt had some sort of HTML problem, so I've lost the will to live and will give up.
But as a courtesy, yes I've got a WiFi problem but I don't believe it's just coverage.
As I'm in the process of considering full fibre I will let that takes its course and meanwhile get a cheap power line adapter to provide an ethernet connection for the TV.
on 26-08-2024 09:00 AM
Hi des09
Are you having WIFI coverage issues with your router?
on 25-08-2024 02:45 PM
My reply was not aggressive in the slightest. It is just that I have already tried to explain how to find out the price of a 266. What you decide to do, is totally up to you.
on 25-08-2024 02:14 PM
Your response seems somewhat aggressive.
Let me explain the sequence of events.
Firstly I came on here for general advice as my setup was failing.
Next you gave me advice.
So with that advice I did a web search for the price.
When I found out it was too much for the size of my problem I then followed up by taking your advice by asking the forum if there was a reduced price through TT.
If this doesn't follow the route you would like I'm very sorry.
The situation now is that I've bought a replacement of the original device in case that solves it, which remains unwrapped so it can go back.
I'm now going to consider a power line device as I believe that will help.
I've also disconnected the entire system as the TV works fine connected to the router wifi direct and the TT box is just missing internet services which of course I can get via the TV.
You see there are simple ways of getting round issues without jumping to the first one suggested.
I just wanted some supporting advice.
The next stage is an upgrade to full fibre at which point I will relook at the whole setup. One part is to get a decent set top box that supports WiFi.
on 25-08-2024 01:48 PM
So after telling me that it was too expensive, it would appear that you do not know how much it costs after all. I told you in your other thread the ways that you can get one, but you seem to want to ignore my advice.
on 24-08-2024 06:42 PM
I am not aware that it is available for purchase as such. If you are having issues with your WiFi coverage then it is an option that can be considered. The support team here will advise further when they are back online, but it maybe after the Bank Holiday.
