Setting up a Chromecast Device on my talktalk router
MickP54
Message 22 of 22
Am trying to set up a chromecast device but am receiving an error message from the SET UP wizard advising me it cant connect and to Disable AP isolation on my router to continue
Ive had a quick look at my router set up page (192.168.1.1) but its not obvious to me where I need to go
Can someone outline the steps I need to take to carry out this adjustment?
My router is
TALKTALK260BAF
and my bands have been seperated
Many thanks
Mick
Mick Pope, TV engineer, grew up in the magic of the 60/70s when we reached for the stars and landed on the moon
21 REPLIES 21
Message 1 of 22
Hi Mick
No problem 🙂
Is there any reason you don't want the eero now?
MickP54
Message 2 of 22
Thank you
Message 3 of 22
Hi Mick
Have you received the eero? You can refuse delivery or return in the returns bag (that comes with in the box)
MickP54
Message 4 of 22
I wish to cancel this order
Can you please make arrangements for this item to be returned
Thank you
Message 5 of 22
MickP54
Message 6 of 22
Thank you for your help and attention
Mick
Message 7 of 22
Hi Mick
The eero is on its way, please allow 48hrs for this to arrive.
Let us know how you get on.
MickP54
Message 8 of 22
Yes please
Thank you
mick
Message 9 of 22
Hi Mick,
The eero has 2 ethernet ports. If you have VOIP too then the digital voice adapter would need to connect to one of the ports. If more ethernet connections are required then we'd advise on looking into a network switch.
Would you like us to send an eero?
MickP54
Message 10 of 22
OK, so will I still have ethernet or will everything be on wifi?
Message 11 of 22
Hi Mick
The eero would replace your current WIFI hub.
Yes they are, I can link to a help page for help with set up.
MickP54
Message 12 of 22
Yep, It's a WiFi Hub I have.......is an eero in addition to my wifi hub or would it replace it? Sorry, not used one before, are they easy to set up, got a range extender on my hub would I need to remove that?
Mick
Message 13 of 22
Hi Mick
I will order this for you, it looks like I can only order a eero now.
Are you currently using a WIFI hub?
MickP54
Message 14 of 22
YES, please do, I would like to get this problem sorted,
Thank you
Message 15 of 22
Thanks Keith.
@MickP54 - Are you happy for me to send a replacement router?
Message 16 of 22
Hi @Debbie-TalkTalk
There is nothing wrong as such (the firewall in the router is on medium), but it does not work. Could you please try a replacement router?
Message 17 of 22
Message 18 of 22
Hi @MickP54
Alas CS50001 is just part of Sagemcom's address in France, but it is near enough. You either have either of these two routers:-
  1. Sagemcom FAST 5364 (aka WiFi Hub)
  2. Sagemcom FAST 5464 (aka WiFi Hub 2)
AP Isolation is disabled and is not configurable from the router's UI.
Can you give me the Chromcast's WiFi specification please, so I can try & help you?
Please can you also log into the router & get me the System Log entries for the time period of a failed connection attempt? You can do this by going to:-
Dashboard > See internet settings > Manage advanced settings > TalkTalk Wi-Fi Hub > Maintenance > Logs
Don't be alarmed by the number of DNS entries in the log, just copy & paste everything from that time period into a PM (to protect your privacy) and send it to me.
Message 19 of 22
HI MickP54
I can see that Keith has offered to help.
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
MickP54
Message 20 of 22
Sagecom CS50001
