Slow speed via NordVPN
will121
Message 7 of 7
I have a vpn on my firestick when I use Netflix or Amazon video my films buffers. Is this Talktalk choking the speed or something else thanks
Will
6 REPLIES 6
Message 1 of 7
Hi will121
Ok, please can you add your TalkTalk account number to the Private Notes section of your Community Profile.
Message 2 of 7
I have not got a landline I am on the total full fibre data only
Will
Message 3 of 7
Hi will121
Please can you also add your TalkTalk landline number to your Community Profile.
Message 4 of 7
All done and updated
Will
Message 5 of 7
  • TalkTalk Telephone number
Skynet_TX
Message 6 of 7
Hi @will121,
What router do you have, and what firmware version is it running (if you know).
If your speed is fine when you are not using the VPN then it is more likely that the issue is with the VPN service, rather than your TalkTalk service. There are some combinations of router and firmware that can be a bit funny with VPN connectivity, but that tends to cause problems with connecting to the VPN at all, rather than allowing you to connect but having poor speeds.
Connecting via VPN will nearly always be slower than a direct connection, as all of your traffic is having to be routed through the VPN providers systems.
For one of the TalkTalk Support Team on this community to be able to look into this you will need to update your community profile to include :
  • Your name
  • Landline telephone number that your TalkTalk service is provided on (this is shown in ‘My Account’) OR your account number if you have Full Fibre with no landline
  • An alternative contact number
This will allow them to identify you, and they will then be able to help.
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk Support Team on this community can see your profile details).
