Slow uplink speed
Wizz Kid
Hi Michelle
Thank you for your reply.
Yes please go ahead and try the optimisation again.
I have disconnected the internal wired phone at the master socket and put the filter into the master test socket as you requested.
Many thanks.
Hi Robot5,
Ok thanks. I've optimised the connection now, please let us know if their is any improvement in speed over the next 24hrs.
Wizz Kid
Hi Michelle
Than you for your reply.
DLM did a profiles change last night, but although the UPlink speed is now 50% higher than normal, the DOWNlink speed is stuck at 2Mbps.
The noise safety margin on the UPlink is around 5dB, the DOWNlink noise safety margin is  close to 10dB. The DOWNlink line loss is now 2dB higher that normal.
Something is keeping the DOWNlink speed low. Router stats below.
Is the line still showing line errors please ?
Many thanks.
DSL synchronization status:
Up
Connection status:
Showtime
Upstream line rate (kbit/s):
731
Downstream line rate (kbit/s):
2048
Maximum upstream rate (kbit/s):
708
Maximum downstream rate (kbit/s):
2492
Upstream noise safety coefficient (dB):
4.9
Downstream noise safety coefficient (dB):
9.7
Upstream interleave depth:
4
Downstream interleave depth:
16
Line standard:
ADSL_G.dmt.bis
Upstream line attenuation (dB):
37
Downstream line attenuation (dB):
56.7
Upstream output power (dBm):
12.6
Downstream output power (dBm):
17.3
Channel type:
Interleaved
DSL up-time:
0 days 6 hours 36 minutes 1 second
26_6_2019
Hi Robot5,
There were some errors on the line prior to the profile change but improved since then - optimisation is still in progress
Wizz Kid
Hi Chris
There have been no more profile changes by DLM since last week.
The DOWNlink speed is still lower than before the BT Openreach repair. I was getting 2.5Mbps and now it is around 2.2Mpbs.
The noise margin seems to be higher than it was before, does this indicate there is more noise on the line somewhere ?
At present the router is connected to the master test socket.
Broadband Information
Up
Connection status:
Showtime
507
2504
624
2940
9.3
6.7
8
32
Line standard:
ADSL_G.dmt.bis
36.4
54.6
12.6
16.9
Channel type:
Interleaved
25_4_2019
Up
Connection status:
Showtime
507
2219
600
2608
7.9
9
8
16
Line standard:
ADSL_G.dmt.bis
40.9
55.1
12.7
17.9
Channel type:
Interleaved
3_7_2019
Any ideas please ?
Many thanks
Hi Robot5,
Your line profile isn't limiting your speed to 2.2Mbps and SNR should be 6db so could you reboot your router and we'll see if the sync speed improves and your router resyncs back on target SNR (6db)
Wizz Kid
Hi Chris
Ok, I will reboot and see what happens overnight this time.
If as you say my line profile isn't limiting my speed to 2.2Mbps, then is it because there is more noise on the line, and DLM is setting the noise safety margin higher than the target of 6dB ?
I will see what it does overnight.
Many thanks.
Hi Robot5,
How are you getting on?
Wizz Kid
Hi Michelle
I re-booted the router yesterday as requested by Chris.
Here is a copy of the stats for today, DLM did nothing last night.
The DOWNlink speed is still 2.2Mbps, and the line attenuation keeps varying, 8dB higher on UPlink,2dB higher on DOWNlink, why does this keep occurring, and is it the reason for the lower DOWNlink speed  please?
Up
Connection status:
Showtime
507
2504
624
2940
9.3
6.7
8
32
Line standard:
ADSL_G.dmt.bis
36.4
54.6
12.6
16.9
Channel type:
Interleaved
25_4_2019
Up
Connection status:
Showtime
507
2211
700
2608
11.4
7.6
8
16
Line standard:
ADSL_G.dmt.bis
44.5
56.6
12.6
18
Channel type:
Interleaved
4_7_2019
Many thanks for your help.
Hi Robot5,
Thanks for the information.
The target SNR is 6db and profile cap is 2.56Mbps so not sure why router is syncing at 2.2Mbps with SNR of 8db - is your router currently connected to your test socket?
Wizz Kid
Hi Chris
Yes connected to the master test socket via a microfilter as requested.
Sorry but could you try rebooting the router again and we'll see if there's any improvement, I really can't see why its not syncing at a faster speed
Wizz Kid
Hi Chris
Many thanks for your reply.
I have today rebooted the router again.
Please let me know if you require any thing else done this end.
I will check the line speed overnight and give you an update tomorrow.
Many thanks.
Hi Robot5,
I can see that your sync speed is now up to 2.4Mbps, could you bump the thread on Monday and we'll see how you're getting on
Wizz Kid
Hi Chris
Ok, I will report back with an update on Monday as requested.
Many thanks.
Hi Robot5
I've checked the connection stats and your line is in sync at 2.3mb.
Wizz Kid
Hi Michelle
I sent in an update yesterday (Monday) as requested, but it does not appear.
So a repeat.
There has been no change to the profiles since last week by DLM. The speed is still as it was on Friday 2.3Mbps after the re-boot of the router.
The noise safety margin is 6.9dB close to the target snr but DLM has not raised the DOWNlink speed to 2.5Mbps. I was getting that speed prior to the repair by BT Openreach.
The UPlink speed is back to normal.
Up
Connection status:
Showtime
507
2397
632
2836
8.9
6.9
8
32
Line standard:
ADSL_G.dmt.bis
37.1
55.4
12.7
18.3
Channel type:
Interleaved
DSL up-time:
3 days 0 hours 31 minutes 9 seconds
8/7/2019
An ideas please ?
Can I just check with you that the home phone has a clear dial tone - no noise or interferance on the line.
Wizz Kid
Hi Karl
There is no noise or interference (that is audible to my ears) on the phone line.
However, it did go completely off at 09:45 and 12:30 (while a call was in progress) today, don't know if you or BT Openreach were working on the line then.
Many thanks.
Wizz Kid
Hi Karl
And also since then the speed has dropped to 2.1Mbps ?
The has been a number of faults on this circuit, so maybe it needs a new pair from the exchange put through ?
Many thanks.
