on 09-05-2024 09:50 PM
My home broadband connection has been dropping on the WAN link multiple times a day for the last few months. I have reported it many times to talk talk through the support chat service and still nothing has been done. I work from home and so many of my meetings have been interrupted. I am really at the end of my temper and do not know what to do.
When I look at the router logs, at the time the problem occurs I get the message
WAN DHCP client (1) stopped
and the LED on the router goes from white to orange for about 3-4 minutes.
I am also getting lots of
| Error | DNS | DNS name resolution failure (_dns.resolver.arpa) |
occurring every few minutes, sometimes more frequently.
on 16-05-2024 09:12 AM
OK, I'll pass it over to our Future Fibre team and ask them to take a look. I'll let you know when I receive an update or they may contact you directly
on 16-05-2024 06:15 AM
Hi Chris,
i haven’t not been in contact with them as i was never given contact info, wasn’t transferred to them when i was trying to fix my issue.
on 15-05-2024 07:36 AM
OK thanks. Just to confirm, have you contacted TalkTalk's freedom fibre support team?
on 15-05-2024 02:45 AM
hi chris,
from previous chats with talktalk support there was no mention of contacting freedom fibre. so i have done that now, waiting on a reply
on 14-05-2024 03:06 PM
OK thanks. Could I just ask, have you tried contacting the Freedom Fibre support team about the issue with your Full Fibre service?
on 13-05-2024 06:30 PM
Hi Chris,
all cables are set up the same as when they where installed and haven’t been unplugged, turned it off for 30 mins. Still has red LOS light on.
on 13-05-2024 03:10 PM
OK thanks. Could you make sure all cables are connected to the ONT correctly then turn the ONT off and leave it off for at least 30 minutes then switch back and check to see if the lights are any different
on 13-05-2024 12:18 PM
hi chris,
The only lights on is a red LOS and green power.
on 13-05-2024 09:52 AM
Hi Spudgun600,
We will really need to take a look at the Full Fibre service. Which lights are currently on, on the ONT?
on 10-05-2024 05:39 PM
hi michelle
i use the old copper line as the fibre line for some reason doesn't work and it hasn't since December 2022. the ont did work for a day then it stopped working and i had to swap back to the old connection just to have internet access. due to having two lines i can not perform a connection test as the talktalk website doesn't allow me to.
on 10-05-2024 06:53 AM
I'm sorry to hear this. Can I just confirm, do any lights change on the ONT when the connection drops or just on the router?
