Sonos Device connecting
Seanyb
Message 13 of 13
I have a Sonos Beam and two Sonos 1 speakers but can no
longer connect them to WiFi. Has anyone had and been able to fix this issue!! I have tried a number of things  already. and spoken to Sonos support. Looks like a router issue
any help greatly appreciated
12 REPLIES 12
Message 1 of 13
Hi @Seanyb
How are you getting on, did you see my Private Message?
Message 2 of 13
Hi Seanyb
Thank you. I've run a test on the line now which is clear.
I'm just sending you a Private Message.
Seanyb
Message 3 of 13
I have updated it again
Message 4 of 13
Hi Seanyb,
Did you also click save at the bottom as I can't see this info in your Community Profile?
Seanyb
Message 5 of 13
Profile updated
Message 6 of 13
Hi Seanyb,
  • Name
  • Telephone number or Account number
  • Alternative contact number
Seanyb
Message 7 of 13
Hi - it’s a Fast 5364-3 T8
Message 8 of 13
Ok, which router are you currently using please? (make and model)
Seanyb
Message 9 of 13
I have rebooted the router, split the WiFi into two SSIDs so I can make sure the device connects to the 2.4ghz channel. I have connected by Ethernet (successfully), I have connected on my daughters WiFi successfully l. It no longer works on WiFi at home. Thanks
Message 10 of 13
How are you getting on? Have you tried rebooting the router?
Divsec
Message 11 of 13
Hi @Seanyb just checked my app updated 7th May, also said I had no devices then changed its mind.
I hope this helps
Divsec
Message 12 of 13
Hi @Seanyb were there any changes preceeding this event? I'm thinking power cut or router disconnection? Or worse still Sonos app update and firmware update.
I've had this from time to time and generally reboot the router to sort it. I also try to have one of my three connected ethernet rather than WiFi.
Good luck.
