Slower on fibre 65 than 35
on 10-04-2023 12:43 PM
Message 7 of 7
On the 24th March I was leaving TT but they offered me a deal to upgrade from fibre 35 to fibre 65. Ive had a solid 36 meg for 18 months on fibre 35 but now on fibre 65 Im getting 27 meg.
After a long chat on the phone to TT and 2 router resets Im now down to 22meg. They are saying two things, fibre 65 only guarantees 29.7 meg and they need 30 days to sort it out.
Im very unhappy with this response but my hands are tied, any suggestions or positive comments are welcome.
- Pete.
Labels:
- Labels:
Speed
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
6 REPLIES 6
on 14-11-2024 09:23 AM
Message 1 of 7
Hi Brian1944
Please can you create a new topic on the Community, we can then take a look at this for you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-11-2024 06:08 PM
Message 2 of 7
It's just a difference of speed, not necessarily wifi reach, @Brian1944.
Same router (if you already have a perfectly good Sagemcom).
If you need any further help, please return to the message board to start your own thread (click on start a topic) and also make sure that you have completed your community forum profile details.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-11-2024 05:17 PM
Message 3 of 7
- I have just agreed to change from 35 to 65 fibre, the reason I haven’t been able to get a signal in all rooms of my house.
- will I get a greater range from the new service also will talktalk supplyme with a new more powerful router
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-04-2023 02:29 PM
Message 4 of 7
Hi Pete,
fibre 65 and 35 are package names and not a true reflection of actual speeds, so on fibre 35, your profile is set at 40mb, allowing the line to achieve upto 40mb if it is capable of this. On fibre 65, the profile is set to 80mb. As your line was in sync at the maximum of 35mb, this will not achieve any more, but these are irrelevant points at the moment as your line is going slower than it should at the moment.
The line test is failing and showing an issue. The only way to resolve this is with an Openreach engineer to asses the fault and repair.
If we send out an openreach engineer and the fault is not with the line, but something within your own property, either faulty equipment or damage to the line caused by your own actions, building works etc, they will charge you for the call out. This is why we are asking questions, to positively rule out any internal issues so you are confident that a visit can go ahead. The first and most likely issue could be the router, so we always ask that another is tested. Testing at the test socket (the Openreach demarcation point) ensures that nothing else is connected to their line and verifies that the cause must therefore be external.
I do want to help deal with this as quickly as I can, but with the test failure, our only option is to progress towards an engineer.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-04-2023 02:20 PM
Message 5 of 7
Karl thanks for the reply but this has only happened since I renewed to fibre 65, and a recent speedtest is showing 2.8 download. Nobody at TT said there was a limit on my line and why was I getting a solid 36 meg for a very long time on fibre 35 now TT are saying the guaranteed min speed for fibre 65 is 29.7 meg, this is not good enough.
There are no problems within my home and its got worse since they remotely checked my line and the asked me to do a reset, nothing personal karl but Im very stressed with having to go through all this especially as I have very serious health issues right now.
Pete.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-04-2023 01:32 PM
Message 6 of 7
Hi Pete,
First, if your line was only capable of 35mb, fibre 65 would not change this. Upgrading to fibre 65 just removed the cap to allow the line to go faster if it can achieve faster. The important bit to note here, is IF the line can achieve faster. If your line had been in sync at 39mb and was predicted to achieve more. then upgrading to fibre 65 may have given more speed, but there is no point in this case, unless you only want the increase in upstream bandwidth.
With regard to your line at this current moment, line tests are failing and showing a possible copper line issue near or within the premises and the only way to resolve this may be through an engineer visit.
Before considering this however, we just need to check a few things with you.
Have you tested another router to rule out a hardware issue ?
Have you tested directly at the 'Test Socket' if you have one ?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
