Solid orange light on Hub
talkuser_917
Message 14 of 14
My router (Sagemcom TalkTalk wifi hub) is showing a solid orange status light, and I am unable to connect to the internet through it. It also isn't broadcasting a wifi ssid, so I am unable to connect to it wirelessly. Connecting to it through ethernet, no internet is provided and I am unable to navigate to the admin interface (ip address 192.168.1.1). I hadn't changed anything, or touched it before all these error symptoms appeared. Line testing is showing the line as having no problem.
13 REPLIES 13
Message 1 of 14
That's great news thanks for letting me know 🙂
talkuser_917
Message 2 of 14
Hi Chris, New router arrived and works great - internet is back up. Thanks for your help!
Message 3 of 14
Message 4 of 14
perfect - thanks for your help!
Message 5 of 14
OK, I'll order the router now, it should be with you within a couple of days
Message 6 of 14
Hi Chris, Yes - that would be great - thanks!
Message 7 of 14
OK, we can send one to test with, would you like me to arrange this?
Message 8 of 14
no - unfortunately the talktalk one is the only one I've got with an adsl port
Message 9 of 14
OK thanks. Do you have another router that you can test with?
Message 10 of 14
yes - and I've left it off for 20 minutes. Also tried the reset pin button, but to no effect.
thanks!
Message 11 of 14
OK thanks. Have you tried rebooting the router?
talkuser_917
Message 12 of 14
No problem with phone service - normal dial tone on line
Chris-TalkTalk
Message 13 of 14
Hi talkuser_917,
Welcome to the Community
Are you experiencing any problems with your telephone service? Is there a dial tone? Any noise on the line?
Anonymous User
