TALKTALK WI-FI HUB Version SG4K100174 keeps dropping out Wi-Fi devices and it keeps crashing
Rainbow20
Message 13 of 13
My wifi devices keep dropping out and the router is regularly crashing with both Wi-Fi and Ethernet devices being unable to go online, this has been happening for the past 3 weeks, this is not a new router and has not happened before.  The white light on the router remains throughout.
Any ideas please, my house will go into meltdown if we are without the internet for more time than it takes to eat dinner.
TIA
12 REPLIES 12
Message 1 of 13
Hi @Rainbow20
How's the connection been? Do you still need help with this?
Message 2 of 13
Morning Rainbow20
I've checked the connection stats this morning, the line is in sync at just under 50mb and there are no re connections showing.
How's the connection been over the weekend?
Message 3 of 13
Hi Rainbow20.
Please can you power down your router for 30 minutes (as this will start a new session) then can you keep the router powered up without rebooting.
I will check the connection stats/speed again on Monday and I will post back on this thread.
Thanks again.
Rainbow20
Message 4 of 13
Yes please, if you could keep an eye on our line that would be great.  We are having some speed issues, where it is jumping from around 25 to 46, I don’t know if this is expected while the system settles down again?  Thank you
Message 5 of 13
Hi Rainbow20
That's great 🙂
Would you like me to check in again with you next week to see how the connection has been? (so you can keep monitoring for a bit longer)
Rainbow20
Message 6 of 13
Hello
Yes, thank you so much, we have received the router and we have been testing it over the last few days.  We are still finding devices that need to be connected, but so far so good.  However, we haven’t been home much to see if it is dropping out.  How long should we test it for?
Message 7 of 13
Message 8 of 13
Hi Rainbow20
Thanks for your reply 🙂
Rainbow20
Message 9 of 13
Hi Michelle, I think that is a great idea, thank you so much. 😊
Message 10 of 13
Thank you. I've run a test on your line now which is clear, however I can see a few re-connections on the line. The router also has the most recent version of firmware. As this is also happening to wired devices then I think we should send a replacement router for testing purposes to rule this out, would this be ok?
Rainbow20
Message 11 of 13
I have updated my profile, thank you Michelle
Message 12 of 13
Hi Rainbow,
  • Name
  • Telephone number
  • Alternative contact number
