Sagemcom FAST5364 dropping wifi
prt23
Message 15 of 15
Our router a Sagemcom FAST5364 worked fine when we first got it. For the last 2 or 3 months we have had problems with it dropping connections within the WIFI network. I use Chromecast over the network but it often cannot find devices which it should be able to find. Often we need to reboot the modem before laptops can find the WIFI printer. Firmware version SG4K100174.
14 REPLIES 14
Message 1 of 15
Hi Paul
That's great news, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 2 of 15
Hi Debbie,
I thought I would leave it a day or two to see how it performed over time.
It has been very stable with no dropouts whatsoever. I can only presume this has fixed the problem.
Thank you very much for your fast response and being so helpful.
Paul
Message 3 of 15
Hi Paul
How's the connection been since the WIFI optimisation was switched off?
Message 4 of 15
Message 5 of 15
Thanks. Will see how this goes.
Paul
Message 6 of 15
Hi prt23,
I've disabled wifi optimisation as requested, this will allow you to manually set a wifi channel without wifi optimisation changing it
Message 7 of 15
Hi Debbie, have added my details. Thanks.
Message 8 of 15
Hi Paul
Please can you add your name and TalkTalk landline number to your Community Profile. We can try switching the WIFI optimisation off first.
Message 9 of 15
Hi Debbie, I have been reading another thread which suggests you tuning off  WIFI optimisation. Does that make any sense.
Other than that I would be happy to try another modem.
Paul
Message 10 of 15
Hi Paul
I think we should send a replacement router for testing, would you like me to arrange this?
prt23
Message 11 of 15
Hi Debbie,
I did as you suggested, and reset the box to factory settings.
This has not made any improvement,  the problem still exists.
Any other thoughts?
Paul
Message 12 of 15
Hi prt23
Thank you. Please let us know how you get on.
prt23
Message 13 of 15
Will try this. Thanks.
Chris-TalkTalk
Message 14 of 15
Hi prt23,
Could you try resetting the router to factory default settings - Restore your router to factory settings - TalkTalk Help & Support
