Constant disconnects after free upgrade
liam007x
Message 20 of 20
Hello Team,
We were given an upgrade over the last few days and an engineer attended my house to fit a new socket and new router.
Since this has happened, my download speeds has gone from stable 9Mbps to now unstable 80kb.... and periods of no internet.
There is no fault with my hardware or setup, the issue started since the upgrade and the engineer visit. All devices in the building are experiencing this fault which leads to the router or line. Router has been power cycled to no difference.
I have also bought a wifi booster as the router is in a new location because the engineer couldn't install it in its original place. No change in problems with the booster installed and setup.
What can you suggest?
19 REPLIES 19
Message 1 of 20
Hi liam007x
Ok, thanks for letting us know.
Please post here again if you do need any further help.
Debbie 🙂
Message 2 of 20
Hello Debbie,
Unfortunately not, I don't have a laptop I can plug in and my desktop is too far away for a cable.
I think at the moment it is doing ok, I have not seen my connection cut off completely since Wednesday which was the main issue. There are still some spikes in speeds which may just be teething problems.
Im happy to close out this post or ticket if you have one 🙂
Message 3 of 20
Hi liam007x
Did you manage to test the speed at the ONT?
Message 4 of 20
Hi liam007x
It would also be worth testing directly at the ONT to run a speed test.
Message 5 of 20
Hello Debbie,
Thanks for the support so far.
Although there was no total disconnects yesterday the speed wasnt the greatest and had some spikes but I think these could just be teething issues.
Ill continue to monitor and will update this post
Message 6 of 20
Hi liam007x
I'm so glad to hear this.
Please can you continue to monitor the connection over the next few days and let us know how you get on.
Thanks again.
Debbie 🙂
Message 7 of 20
Hello Debbie,
Just a quick update, I have not changed anything as of yet.
When I got home, my father advised that he contacted TalkTalk in the morning and they identified a fault which was also resolved a little bit later on.
I have been running a constant ping since I got home and not seen any spikes like I did the last couple days which is fantastic.
Not sure if this was due to turning off the Wifi optimisation or the fault that was resolved but so far so good.
Message 8 of 20
Hi liam007x
No problem. It's switched off now, please let us know how you get on.
Message 9 of 20
Thanks Debbie,
Yeah if you can turn it off and ill try setting up the channels later on and see.
Message 10 of 20
Hi liam007x
No it wont affect the connection now, only when you start to change the wireless channels yourself.
Change your wireless channel
Only we can switch the WIFI optimisation off for you. You can't do in the router admin page.
Message 11 of 20
Hello Debbie, will that disconnect the current users connected at the moment?
Im away from the house right now so cant really do much testing, but I got some users at home that will most likely be using it now.
Is that somthing I can turn off myself later on via the router admin settings?
Message 12 of 20
Hi liam007x
I can try switching the WIFI optimisation off so you can try different wireless channels, would you like to try this?
Message 13 of 20
Hello Debbie,
It is a Hub2. Same as what I had previously before the upgrade
Message 14 of 20
Forgot to say, ill check the lights on the ONT tonight when im getting issues to see if anything changes.
I dont know if this will be possible as the spikes can last from 15 secs to 3minutes so could be back up by the time I get down and get the ladders out.
Message 15 of 20
Message 16 of 20
Hello Debbie,
Thanks for checking, the connection is not always at fault but rather sporadic.
I dont think it will be possible for me to connect a device directly to the ONT as the engineer installed it above my fridges and I dont have a cable long enough to reach my desktop on 2nd floor.
Originally the router was located on the 1st floor and the master socket was on the ground floor. The engineer installed this new router on the ground floor near the new ONT above some fridges.
Message 17 of 20
Hi liam007x
Thank you. I've run a test on the line now which hasn't detected a fault. Have you noticed if any of the lights change on the ONT when the connection is unstable? Would it be possible to connect directly at the ONT for a short period with the router removed to see how the connection compares please?
Message 18 of 20
Hello Debbie,
I have added my landline number to the TalkTalk number section in my profile, hopefully thats the right place.
Message 19 of 20
Hi liam007x
Please can you add your TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Anonymous User
