TalkTalk Wi-Fi Hub version SG4K100174 Intermittently Freezes.
JohnSB
Message 16 of 16
Hi there! I am getting desperate here, as TT refuse to acknowledge that there is a fault with my router. Every now and again it starts to slowly drop off devices until it freezes completely. The white light remains, untl I am forced to attempt a reboot. Here we have the second issue.  The router does not turn on immediately on the first attempt. It can take up to 45 minutes to get it to go to an amber light. I have tried everything. Reset. Brand new cat 10 cables. cables attached before and after boot in evry possible combination. A new BT Mastersocket 5c. The outside box has been checked, and re wired. The router is in optimal position. My job is in IT repair servicing and build, so I know a tad about it.
I have contacted TT on numerous occasions over the last few years about this. Despite the last engineer recommending that the router be replaced (he would have had he had one he said), I still have this clearly faulty one. The only problem is all the router diagnostics show no fault. I presume this is because of the nature of the crash. This is why TT refuse to provide a replacement  - they can gladly have this one back!
The other thing I have noticed, is that the router logs show that a connection is made all the time; despite it being disconnected and powered down when I have to reboot and reste after said Freeze/crash.
I am fed up to the back teeth of going through the rigmarole of checking each item off the TT telephone engineers checklist, and trying to explain the issue.
How do I get a replacement router? Any ideas would be most welcome. I suppose I should just bite the bullet and spent a few hundred quid on a branded one?
Many thanks in anticipation of some much meeded help!
John
15 REPLIES 15
Message 1 of 16
Morning @Cody+
I'm sorry to hear this. Please can you create your own topic and we'd be happy to look into this for you.
Message 2 of 16
I asked for a replacement - on the call for about an hour before they accepted there was a problem, but the line still disconnects when not in use, then takes 10 minutes to wake up - apparently the solution is to add personal data to my profile on this forum, which really isn't the most helpful or technical solution I've been given, so I didn't and my fault has been put on the 'ignore' pile... as I didn't get any response
Message 3 of 16
Hi JohnSB
Message 4 of 16
Hi JohnSB
Apologies for this.
I've ordered you a replacement router, please allow 24-48hrs for this to arrive.
Message 5 of 16
Wow! That would be amazing; Thank You!
Message 6 of 16
They will replace it if I ask them to do so!
Message 7 of 16
Oh, thank you. They have already done this (they say), I would estimate 6 to 7 times over the past 24 months, maybe more. The diagnostics on the router show no fault. So they won't replace it, despite my being told by the engineer it needed changing. But thank you.
Message 8 of 16
In that case, I will ask TalkTalk to investigate it for you.
Message 9 of 16
Hi Keith. If affects everything; It usually starts with the Wireless devices, then after a few minutes the wired devices go and the router is effectively crashed.
Message 10 of 16
Hi @JohnSB
One question of my post that you have not answered as yet, is this only affecting wireless connections or the Ethernet ones as well?
Message 11 of 16
Thanks Keith. I don't know if my previous message sent to you was recieved. I'm sorry you are correct they are Cat 8 not 10; they are short cables to connect to the TV and a powerline adaptor, and I have one 5m one to connect a laptop when needed. I changed them because TT insited that I check all cables prior to an engineer visit, so I upgraded them. The engineer even recommended a replecement, but that was well over a year ago now. I'm not asking for the earth from TT, just a swap out of devices, but if you think you can help then help away!
John
Message 12 of 16
HI Michelle. I have put my details in as requested. Thank You.
Message 13 of 16
Hi John,
If you can update your details as requested, we can take a look.
Message 14 of 16
Hi @JohnSB
Cat 10, this standard has not yet been ratified. While some places sell cables claiming to meet this specification, the current highest ratified classification is Cat 8. Why would you even need Cat 10? Cat 6 is the highest I would use. The use of anything in the IP networking world that is of an unratified standard, can at best only be thought of as experimental. This could mean it does some things better, but equally, it might encounter problems with more basic requirements.
Where are you using these cables?
What devices are affected by this, wired (Ethernet) or wireless or both?
Message 15 of 16
Morning John,
  • Name
  • Telephone number
  • Alternative contact number
