TalkTalk WiFi Hub keeps losing WiFi Connection
on 26-03-2022 09:47 AM
Hi, I have a TalkTalk Wi-Fi Hub version SG4K100130 which over the last 2 weeks seems to lose its wifi connection to some devices overnight. Basically, in the morning most of my devices have no internet connection. When the WiFi hub is rebooted the connection is restored. I have monitored this with a wifi analyser and it appears that the 2.4GHz channel is at fault as in the morning this channel is missing. There does not appear to be any problem with the 5Ghz channel. How can I resolve this problem so that the router does not need rebooting every morning?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 11-04-2022 07:55 AM
Hi Jeremy
If you do experience any further issues then please let us know.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-04-2022 05:26 PM
Hi Debbie,
I have tried the new router but it does not seem to provide as good wifi coverage through my house as my previous router. i have reverted to my previous router which now seems to be functioning correctly and not loosing the 2.4Ghz signal. in addition, Openreach have upgraded me to full fibre this week and that seems to have improved the stability. I'll return the new router to you.
Thanks for your help.
Jeremy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-03-2022 06:27 AM
Hi Jeremy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-03-2022 06:21 PM
Hi Michelle,
I thought that the firmware update had fixed my problem but it has reoccurred today. Please could you send out a replacement router for testing with a router returns bag so I can see if it is router related.
Many thanks
Jeremy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-03-2022 06:46 AM
Yes, no problem. Please let us know how you get on 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-03-2022 05:29 PM
Hello Michelle,
I had an update to the wifi hub firmware yesterday which might have fixed the problem. Can I let you know tomorrow when I will have had more of a chance to see if my router fault has reappeared.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-03-2022 07:23 AM
Would you like us to send a replacement router for testing purposes? We would also send a router returns bag so that one of the routers can be returned.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-03-2022 01:29 PM
Fair enough, I haven't seen the analyser output. I will ask TalkTalk support on this forum to consider offering you a replacement router. You will not need to do anything now, until they contact you on here, hopefully, tomorrow.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-03-2022 01:11 PM
It is definitely the router that stops transmitting. With a wifi analyser next to the router there is no 2.4GHz channel showing. There is also very little interference around the channel (11). I'm going to give TalkTalk one last chance on Tuesday when hopefully I can contact them with the router not transmitting on 2.4GHz so their diagnostics might pick something up. Failing that I'll get them to turn off wifi optimization and get back to you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-03-2022 01:01 PM
The router is most likely still transmitting it, but if the interference is bad, then yes, your device might lose all signal on that band.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-03-2022 12:32 PM
Keith I appreciate that but I was asking if it is technically possible that interference on a channel results in the WiFi hub not transmitting on the 2.4Ghz band entirely.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-03-2022 11:45 AM
I have told you how to get WiFi optimisation disabled first, please do this, otherwise, any suggestions I make will soon be overwritten by this feature.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
27-03-2022 11:22 AM - edited 27-03-2022 11:23 AM
Just spent 2 hours chatting with Talktalk to absolutely no avail as they will basically not believe that I have a problem. One thing I keep trying to get cleared up is whether interference on a wifi channel can stop the wifi hub from transmitting on the 2.4Ghz band entirely? When I say transmitting entirely I mean no 2.4GHz transmission at all until the router is rebooted. Any thoughts?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-03-2022 02:52 PM
From my first reply:-
Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-03-2022 02:21 PM
How do I disable wifi optimisation?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-03-2022 12:50 PM
Before doing that, is WiFi optimisation disabled on your Sagemcom? There is no point in moving forward with this until then.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-03-2022 12:04 PM
Hi Keith, thank you for the reply. Please could you send me the guide
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-03-2022 11:50 AM
Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a by-product of the popularity of Wi-Fi.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Gow to get out of my contract. Due to router issues in Broadband
- Intermittent internet connection and infuriating tech support in Fibre
- Upgrade from FTTC (Fibre 35) to FTTP in Fibre
- Gmail treating emails from TalkTalk account as Spam in Email
- recent degradation of connectivity (TalkTalk Wi-Fi Hub Version v1.05t) in Broadband
