Unreliable connection
eden798
Message 2 of 2
Hi, I need to speak to someone at talktalk about my issue but can't find anywhere to do so?
I have been a customer since 2019, and have had this problem for a while. At least once per day (most times it happens more than once), my internet will cut out for no reason. The hub usually is not affected, it just stays with the white light on. This is very frustrating as me and my partner work from home, and rely on the internet connection being stable, but it is very unreliable. Would it be possible that we need a new router? As I have had this one since 2019, so it is 6 years old now.
1 REPLY 1
Message 1 of 2
You cannot speak to anyone via this forum. However, I might be able to help you.
Which make/model of router do you have?
The information below is provided by TalkTalk, for confirmation, please contact @Debbie-TalkTalk or @Lorrainef.
If you need further help or if we need to take any details such as personal information about your account like phone numbers, account numbers, etc, one of the TalkTalk team will jump in and help out.
