on 16-12-2022 04:28 PM
I can't connect to my work's VPN - I understand that may need to make a firmware change to my router
Your assistance would be appreciated
Many thanks
on 30-12-2022 10:58 AM
Hi vodkajo
Do you still need help with this?
on 19-12-2022 10:25 AM
Hi vodkajo
Thank you. Are you currently using the HG633 router? This should work ok with VPN.
Have you tried factory resetting the router using the pin hole reset for ten seconds?
Thanks again.
on 19-12-2022 10:18 AM
I've added the information that you requested
on 19-12-2022 06:55 AM
Hi vodkajo
Apologies for this.
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
on 16-12-2022 08:32 PM
Hi @vodkajo,
If you have the Sagemcom Wi-Fi Hub (which has one single LED, and a bronze colour behind the holes on the front), then this may well be caused by the firmware version. The support team here may be able to change the firmware version, however they will probably not be around until Monday now.
For one of the TalkTalk Support Team on this community to be able to look into this you will need to update your community profile to include :
This will allow them to identify you, and they will then be able to help.
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk Support Team on this community can see your profile details).
