VPN Not Working
Bobski92
Message 7 of 7
We have recently had a new VPN set up at work and I cannot connect through my Talktalk router.
When connected to hotspot on my phone (Vodafone) it works perfectly.
Has anyone else had this or have any ideas why this has stopped working? I have read a few articles on here about the router being the issue?
My router is a TalkTalk Wifi Router Ver. SG4K10002816t
Many thanks
Rob
Many thanks,
Rob
6 REPLIES 6
Message 1 of 7
Hi Rob
Have you tried the HomeSafe settings suggested by Skynet_TX?
Skynet_TX
Message 2 of 7
There are a few tips mentioned in this article like turning off HomeSafe etc. Would be worth checking that article. But if those tips don't help then hopefully the staff here might be able to assist when they pick this up tomorrow.
Message 3 of 7
hey Skynet
To be honest with you, I have just been using TeamViewer up until now. But they have cancelled our subscription to that as they moved us to SmartVPN!
Many thanks,
Rob
Skynet_TX
Message 4 of 7
ok, the world of 'Apple' is a mystery to me, so I'll leave this one to the staff here to respond to !!
You say that your company have set up a new VPN, so does that mean you have been able to get onto a different VPN using this same MacBook and this same router ?
Bobski92
Message 5 of 7
Hey Skynet_Tex
Thanks so much for the quick response!
So I am on a MacBook Pro, but I am trying to connect using a program called SmartVPN then use Microsoft Remote Desktop  after I have connected to my works router.
I hope that makes sense, I'm sorry but I'm not overly tuned into these things!
I have updated some of my credentials on my community profile as you mentioned so hopefully they come back to me.
Thanks once again,
Rob
Many thanks,
Rob
Skynet_TX
Message 6 of 7
Hi @Bobski92,
The Sagemcom router that you have can sometimes have issues with VPN connectivity, however that tends to be a problem with the brand new firmware (SG4K100130) which your router does not yet have. The version of firmware you are on does not tend to have problems.
Do you know what VPN software you are using, or do you just use the built in Windows 10/11 VPN ?
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk staff on this community can see your profile details).
