VPN Stopped Working
RWoodward
Message 9 of 9
My TalkTalk Router has just stopped allowing my work VPN to connect. I've lost half a day of work so far trying to get it working again. It appears this might be a firmware issue and you can't download the firmware direct so TalkTalk customer service need to fix it for you?
Please help ASAP.
Robin
8 REPLIES 8
Message 1 of 9
Hi RWoodward
That's great, thanks for letting us know.
Message 2 of 9
Thanks Chris, this seems to have worked for now. I had to update some of the settings to get the internet pass through to my WiFi router to work, but all sorted now.
Message 3 of 9
OK, I'll update it now, it should complete in a few minutes, please don't switch off your router
Message 4 of 9
Yes, Please do ASAP.
Thanks,
Robin
Message 5 of 9
OK. I can try a different firmware version, is it OK to do this now, it will take a few minutes to complete?
Message 6 of 9
Hi Chris, I have a TalkTalk Wifi Hub - Sagemcom Device ver. FAST 5364-3.T8
Chris-TalkTalk
Message 7 of 9
Hi Robin,
Which router do you have?
Message 8 of 9
I assume that you have the Sagemcom WiFi hub & that its firmware has recently been updated? I have asked one of TalkTalk's support to pick your thread up and fix it for you.
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
