on 24-04-2022 08:25 PM
I currently have the TalkTalk router behind a PFSense firewall and using as a repeater. Is there a way to download and install the latest firmware myself without changing my network configuration?
Hardware VersionSoftware VersionGUI Version
| FAST5364 3.00 |
| SG4K10002816t |
| 3.7.8 |
Thanks!
on 26-04-2022 06:52 AM
Hi CarlosM
Thank you 🙂
I can see that the firmware updated over night to the latest version. I have also switched off WIFI optimisation.
on 25-04-2022 07:07 PM
Oh ... Debbie. Can you also make sure that channel hopping is turned off after the upgrade. Thanks!
on 25-04-2022 06:59 PM
The router is now connected directly to the router. Ready when you are 😉
on 25-04-2022 09:31 AM
Hi CarlosM
Thank you.
on 25-04-2022 09:28 AM
Thanks for helping! The router is currently behind a firewall. I'll move things around when i get back from work to connect it directly to the modem.
on 25-04-2022 08:46 AM
Hi CarlosM
Is your router switched off at the moment? I'm unable to connect to your router.
24-04-2022 08:46 PM - edited 24-04-2022 08:47 PM
Hi @CarlosM,
You can't download and install the firmware yourself, the only way for it to be installed is for the FAST5364 to be connected as your 'modem', and to either wait for it to install automatically overnight, or for the support team here on the community to manually push the firmware to your router.
