VPN and Whatsapp not working.
rajkp
Message 12 of 12
On my iPhone I am unable to connect to whatsapp on wifi at all. everything else works. I was unable to make whatsapp calls on wifi on my android phone and my partner is also unable to make whatsapp calls. however her messages do come through.
Also an issue is I am unable to connect using VPN most of the time. every now and again it does connect but not for long.
How can this be sorted? firmware update? Thanks.
RAJ
11 REPLIES 11
Message 1 of 12
Medium is the default firewall setting.
Glad it's working now.
rajkp
Message 2 of 12
The firwall set to medium has solved both my issues. many thanks to you both.
Message 3 of 12
The firewall should be set to medium on the 5364. If that doesn't work, then I will need to know which VPN Client app that you are using.
rajkp
Message 4 of 12
I have re-tested and neither is working still.
I do have the Sagemcom FAST 5364.
Firewall is set to custom for some reason, pretty sure I've not done that, is that the default?
Cheers,
Raj
rajkp
Message 5 of 12
Cheers,
Raj
Message 6 of 12
Hi Raj
Have you had a chance to retest ?
Does the VPN work now ?
Message 7 of 12
Hi Raj,
The router is now running with the latest firmware, reboot your devices when you can and retest and let me know please.
Message 8 of 12
Hi Raj,
I'll update your router firmware this morning, to the later version V158.
I'll post back as soon as this is completed.
Message 9 of 12
I Have updated that now.
Many thanks,
Raj
Message 10 of 12
2. What firmware is it running?
3. If you have the Sagemcom FAST 5364 router, what firewall level is it set to,? It needs to be on medium, not high.
Message 11 of 12
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if you are reporting a fault.
We will then reply via this thread in our Community with any further advice or next steps.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you.  Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
Please post back on this thread when this has been done.
