VPN blocked
Jmarson
Message 11 of 11
I have been using a VPN for work for 18 months without issue. I tried to connect this morning and it is being blocked. My IT department have tried everything and there is no issues their end and have said it is being blocked by TalkTalk
10 REPLIES 10
Message 1 of 11
Hi Jack
I have ordered the router and you should receive this within the next 24-48hrs.
I will also speak to our Complaints Team in regards to your complaint.
This help page also provides some further information Raising a complaint
Jmarson
Message 2 of 11
Debbie, this really isn't good enough, please can you pass me details to make an official complaint. In the times we are in with the Prime Minister advising people to work from home, you cannot expect people to be unable to work due to a "firmware update". Please can you send me a new router on a 24hr deliver and provide me with tracking details. I will also await complaint details.
Jack
Message 3 of 11
Hi Jmarson
Our Products Team are investigating if this issue is related to the routers firmware update and certain VPN clients.
The only fix at the moment would be to send a different router, apologies for this.
Jmarson
Message 4 of 11
Debbie, I cant really afford to wait for a new router. This router has never had an issue before, why would it need changing now?
Message 5 of 11
Hi Jmarson
Thanks for the additional information.
I think we should send a different router for testing, would you like me to arrange this?
Jmarson
Message 6 of 11
Thanks Debbie, I have updated my profile. We use Microsoft PPTP. I used a friends Wifi last night and connected fine so the issue is definitely with Talktalk. Thanks
Message 7 of 11
Hi Jmarson
Please can you add your TalkTalk landline number to your Community Profile, we can then look into this further.
Can you also confirm which VPN client you are using?
Skynet_TX
Message 8 of 11
Hi @Attridb,
For the staff here to be able to help you will need to start your own topic on the community, as the staff here can only help one customer per topic. You would also need to complete your community profile in the way that I have described in my reply above so that the staff can identify you.
Attridb
Message 9 of 11
We have the same issue. Worked fine until this morning. IT department have said it is not the VPN client and asked us to test on a different provider. We tested it on a Plusnet WIFI and connected straight away. Tried again on TalkTalk still not working. IT department says there is an issue at Talk Talk. Frustrating to say the least. Not been able to work all day. Checked everything and no joy
Skynet_TX
Message 10 of 11
Hi @Jmarson,
What model of router do you have ?
What VPN software are you using ?
Have you checked the tips here, particularly the Homesafe settings, just in case they have been magically switched on !
If you are currently trying to connect from wireless devices then is it possible to try from a wired device, to see if the VPN works over a wired connection.
