on 19-01-2022 10:05 PM
My VPN connection to work has stopped working and I am getting an error message which says "Error 619 : A connection to the remote computer could not be established, so the port used for this connection was closed."
It was working OK on Tuesday 11 January, but not when I tried it on 16 and 17 January and it has not worked since. I have noted that a number of users appear to having a similar problem from Thursday 13 January.
The router which we have (with no problem for about 2 years) is a Sagemcom Fast 5364.
Please can you let me know if there is a solution to this issue as I need to be able to work from home which I am unable to do at present.
Many thanks,
Alistair
Answered! Go to Solution.
on 19-01-2022 11:21 PM
I'm in the same boat stuck working from home with no Windows 10 PPTP /L2TP VPN connection and other issues since early hours this morning (19th)
I can confirm my firmware is SG4K100130 on a Sagemcom 5364.
Why can't firmware downgrades be pushed? This is hurting!
on 19-01-2022 10:12 PM
Hi @dlotnu,
What VPN software are you using, is it the built in Windows 10/11 VPN ?
If you browse to http://192.168.1.1/ does the 'version' toward the bottom of the screen say SG4K100130 ?
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
