on 20-01-2022 12:07 PM
Similar to other recent posts, I can no longer connect to my works VPN. It was working fine on Tuesday but failed to connect yesterday. Our support team at work has done all the checks their end and there are no problems. I can also tether into the VPN using my mobile, so it appears to be a problem with my broadband/router.
Can you please advise?
on 03-03-2022 11:34 AM
Hi Steve
Our Products Team have apologised and have said they will ensure it stays on current FW now (until new tested FW is available)
on 03-03-2022 11:31 AM
Thanks. All is working now. Can I ask why it was rolled back? Can you put some sort of flag on the account to lock the firmware and not change it without approval/notification.
on 03-03-2022 11:25 AM
Hi SteveM-IT
The firmware was rolled back in error, apologies for this. I've fed this back to our Products Team.
I have changed the firmware back again.
on 03-03-2022 11:15 AM
You will find all the details in Lynne's profile - it's here line and connection, I'm just the middle-man
on 03-03-2022 11:11 AM
Hi SteveM-IT
Apologies for this. I will need to check your firmware again.
Please can you add your name and TalkTalk landline number to your Community Profile.
on 03-03-2022 11:09 AM
This issue has re-occurred today. None of our other users are having any issues connecting to our VPN - have checked and tested the PC VPN connection, am in the process of rebooting the router.
Can you please investigate as a matter of urgency. Has the router firmware been upgraded again?
on 20-01-2022 02:08 PM
Hi SteveM-IT
Yes that's correct.
We are currently rolling out new firmware to all Sagemcom hubs. It's this FW version which some VPN clients, mainly Microsoft seems to be affected.
Hope this helps.
on 20-01-2022 02:02 PM
Right, so you updated the firmware then?
Just so I know. It's not a setting or anything on the router, it's a firmware upgrade. That's fine. I would question why it suddenly stopped working having been fine for months though? Was an upgrade applied automatically or something? What changed?
on 20-01-2022 01:57 PM
Hi SteveM-IT
If the VPN - Microsoft stops working with the Sagemcom hub 130t FW then we can send a Huawei WIFI hub.
We can change the FW but this wont resolve the original DNS issue (which was what the FW 130t was to resolve)
on 20-01-2022 01:50 PM
Thanks Karl
Can you let us know what you did, in case we get other users with the same issue, or the router resets after an upgrade or something?
Be useful for other users to know too.
on 20-01-2022 01:21 PM
You're Welcome 🙂
on 20-01-2022 01:19 PM
Hi Karl
That's worked. Thanks for your help in sorting this out.
Lynne
on 20-01-2022 01:11 PM
Hi Lynne
I've made a change to the router, can you test and see if the VPN works.
on 20-01-2022 01:03 PM
Hi Karl
I've added my number to the community profile.
Lynne
on 20-01-2022 12:41 PM
Hi Lynne
Can you add your home phone number to your 'Community Profile' and I'll look at the router remotely.
20-01-2022 12:35 PM - edited 20-01-2022 12:42 PM
I'm Lynne's IT Manager! We use standard Microsoft RAS, and the Windows VPN client, and can connect over PPTP or L2TP/IPSEC. The VPN was working fine until a couple of days ago and has stopped. I am assuming it must have done some sort of remote upgrade. Google tells us of many VPN issues using this hardware and firmware - SG4K100130 / Sagecom Fast 5364
Lynne can connect her PC to a mobile hotspot and through to the VPN absolutely fine - the issue is definitely with the TalkTalk hub.
We have multiple users with different ISPs, most have no issues. Virgin recently resoled their new Hub5 issue with a firmware upgrade. BT, Sky users etc have no issues.
on 20-01-2022 12:14 PM
What router are you using ?
Which VPN client are you using, or are you using Windows own VPN ?
Do you know what VPM Protocol this uses, PPTP or L2TP.
A recent Windows update from Microsoft has broken the Windows VPN using L2TP however they do have an update available.
