What upload/download speed should l expect
Crosbysea
Message 3 of 3
Can you tell me what speed up/download I  should expect
Chris-TalkTalk
Message 1 of 3
Hi Cosbysea,
Can you also please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
Please can you give me something to go on here? What package are you on & what is the minimum download rate that TalkTalk quoted you? Then, if you log into whatever router you have & tell me what download rate it is displaying (assuming that you are not on a Full Fibre package). Then what speed test figures do you get from a device & is it a wireless or a wired (Ethernet) connection to your router?
Then I will be able to help you.
