Wi-Fi Router Dropping Wi-Fi
Doozy
Message 22 of 22
Hi there I have been having problems with my router (Sagem Talk Talk Wifi Router) dropping WiFi connections to both devices on the 2.4Ghz and 5Ghz channels.
Nothing has changed in my setup recently so unsure what it could be. I have noticed that I have lost the white light being on after it has connected back to Talk Talk (After a reset.) I only see the orange blinking light as it connects.
The Wi-fi router has plenty of airflow around it so shouldn't have overheating issues should it?
I bought this router when they first came out so could it be old and develop a fault?
Many Thanks in Advance,
Steven Aldus
Catch Ya In Da Future
21 REPLIES 21
Message 1 of 22
The difference in sync speed isn't likely to make any noticeable difference. The router will probably sync at a slightly different speed every time you reboot it as fluctuations in background noise will cause the  router to resync at slightly different speeds
Message 2 of 22
I have plugged in the old router and now it has a profile of 45.86 Down and 9.10 Up.
Plugging in the new router sees a profile of 43.4 Down and 7.3 Up!
Why such a variance? Will it matter? I guess the 60 profile was when I had an addon or something when I first moved into the property.
Message 3 of 22
Hi Doozy,
Have you checked the line speed recently with the old router as the line test is showing that recent speeds have been no higher than 48.5Mbps and the average is 47.5Mbps?
It's fine to use the old filter
Message 4 of 22
Afternoon Debbie,
I have received the new router and installed it but have a couple of questions.
Does the new router need settling in for line speed as the received speed profiles are now much lower than the old router? I used to have 60 down and 9 up! Now I have 43 down and 8 up!
The new router won't lock on to a signal with the supplied ADSL filter but works with my old one. Is it okay to use my old filter still?
On a side note the Wi-Fi signals seem solid now 😄
Message 5 of 22
Message 6 of 22
Morning Debbie,
The new router is due to be delivered sometime today by Yodel.
Many Thanks in Advance.
Message 7 of 22
Hi @Doozy
Have you received a notification for the router delivery?
Message 8 of 22
Hi @Doozy
Please let us know how the connection compares with this router.
Message 9 of 22
Morning Michelle.
That would be fantastic.
Message 10 of 22
Thanks for confirming. Would you like us to send a Sagemcom router instead to see how the connection compares?
Message 11 of 22
It is indeed the DF8041W.
Device Type:DG8041W
Description:EchoLife DG8041W Home Gateway
SN:(Removed Just in Case)
Hardware Version:I.1.01
Software Version:v1.05t
Message 12 of 22
Sorry for delay. I have now updated my telephone number. 😄
Message 13 of 22
Thanks @KeithFrench
@Doozy Have you added the correct landline number to your Community Profile? I can check which router you have.
Message 14 of 22
Hi @Doozy
Are you sure that you have a Sagemcom router, I can see that in your trace it is a Huawei router (they do look similar)?
If it is the Huawei DF8041W, then this will need to be changed out for the Sagemcom FAST5364, as the Huawei has a bug that causes instability.
Message 15 of 22
Hi Keith here is the report zip file that you require.
Screenshots to follow in your PM 😄
Message 16 of 22
Hi @Doozy
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 17 of 22
Can you please send me out the guide?
Doozy
Message 19 of 22
Hi there thanks for your replies. I am willing to diagnose my router for sure 😄
Message 20 of 22
Hi @Doozy
@Anonymous has asked me to help you.
