Wi-Fi lost to Thermostat
on 12-04-2024 02:40 PM
Message 11 of 11
The Wi-Fi connection to my Nest thermostat dropped out and despite resetting the router & the thermostat I’m still not getting a connection. I keep getting a message saying that my network is either hidden or out of range -neither of which is true - the router is about 12 foot away from the thermostat. I’ve been in touch with Google & they’ve sent me a replacement but I’ve noticed lits if people have posted about this same issue. Before I go through the rigmarole of installing a new thermostat I want to check whether the fault actually lies with TalkTalk network or equipment?
Labels:
- Labels:
Connection
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
10 REPLIES 10
on 18-04-2024 06:35 AM
Message 1 of 11
Hi Vonney
Ahh it's no problem. I'm glad everything is working for you again 🙂
Thanks for letting us know 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
17-04-2024 07:13 PM - edited 17-04-2024 07:14 PM
Message 2 of 11
Thanks for picking this up. I received a new thermostat front from Google and fitted it/set it up today. Normal service has been resumed!!! 🙂. Must have been a software fault in the thermostat.
Sorry for starting hares running but when the issue started I checked the TalkTalk community and posts on there led me to think it was a TalkTalk issue! As if 🤣🤣😂😂😂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-04-2024 07:20 AM
Message 3 of 11
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-04-2024 03:25 PM
Message 4 of 11
From a mobile, it can be difficult as you have to use the "Show sections" and "Show subsections" which look greyed out. Plus where the logs are concerned they cover many more pages than those seen on a desktop.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-04-2024 03:16 PM
Message 5 of 11
I’m using a mobile. I’ll try from a pc later.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-04-2024 03:10 PM
Message 6 of 11
Please can you give me a screenshot of this, are you using a PC or mobile device to access the router's UI?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-04-2024 03:08 PM
Message 7 of 11
I’ve tried to access maintenance logs about 6 times, but every time I get to step 5 of your instructions (TalkTalk Wi-Fi Hub) I just get taken login screen and keep going round in the same loop!!!
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-04-2024 01:09 PM
Message 8 of 11
Please can you log into the router & go the logs:-
Dashboard > See internet settings > Manage advanced settings > TalkTalk Wi-Fi Hub > Maintenance > Logs
Please do not try & filter them out. Then find any log entries for the time when u try to connect this to the router & paste them into your reply.
The security mode is automatically negotiated between the device & router and they choose the highest one that they both support. This would normally be WPA2 Personal, but it depends on how this is configured within your router.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-04-2024 01:00 PM
Message 9 of 11
Hi @KeithFrench
The thermostat can connect to either band. The router is Sagem, which is fully connected - stable light on the front.
Doorbell, fire/smoke alarms, TV & phone are all on 5mghz according to router admin page. Nothing connected to 2.5mghz.
Completely at a loss at why thermostat can’t see or connect to router. Going to try new thermostat that’s been sent to me - in case it’s the thermostat that’s faulty. Just one question before I do this. Can you tell me what security of network is - if I have to manually type in router name it asks me select from a list. Is it WPA2??
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 12-04-2024 02:58 PM
Message 10 of 11
Hi @Vonney
Which WiFi band is the thermostat trying to connect to, the 2.4 or 5GHz band?
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
