Wi fi disconnects daily
shvsgrey
Message 11 of 11
Hi,  the WiFi signal from the supplied Sagemcom  Fast router has been disconnecting multiple times over the last 3 days.  My Ethernet connected devices remain unaffected. The router light remains a steady white. I have  reset the router back to factory settings but the WiFi problems still persist.  WiFi is lost on both 2.4 ghz and 5ghz channels. To get the WiFi signal back i have to switch the router off for 30 seconds and wait for the connection.  Once reconnected speeds are normal as expected. After a while of usage the Wifi disconnects  again and i have to start the process .
10 REPLIES 10
Message 1 of 11
That's great shvsgrey, thanks for letting us know
shvsgrey
Message 2 of 11
Hi Debbie,
The router has arrived and the WiFi / broadband is now working again with a good connection and good speeds.  Over the weekend the old router failed  as I was only getting a flashing amber light and no connection.
All is good now though . I will send the old equipment back in the supplied prepaid package .
Many thanks again for your help and the fantastic service.
Message 3 of 11
Message 4 of 11
Hi shvsgrey
Ahh thank you 🙂
I will check in again with you next week to see how the connection is with the new router.
shvsgrey
Message 5 of 11
Many thanks for your help Debbie , superb service, i will keep you informed regards the connection. Thanks again.
Message 6 of 11
Hi shvsgrey
No problem 🙂
The router is on its way (and a pre paid returns bag) please allow 24-48hrs for this to arrive.
shvsgrey
Message 7 of 11
Hi Debbie , yes please will there be a pre paid envelope to return the old one just in case it is the router ?
Thank you
Message 8 of 11
Hi shvsgrey
No problem. Would you like me to send out a router now?
shvsgrey
Message 9 of 11
Hi Debbie,  thanks for quick response. There has been no router sent for testing for this issue. I had a replacement router sent out in August 2023 for a different issue (router would do nothing but flash)
Message 10 of 11
Hi shvsgrey
Have we recently sent you a replacement router for testing?
Anonymous User
