Using HG633 router as a wifi extender/access point
BroadbandHog
Message 2 of 2
Hello, I've got a Sagemcom router for my fibre broadband connection, which works fine for our PC, phones and Hive Home Hub. We recently bought a new Epson WiFi printer which we keep in a different room from the PC and I want to set up my old TalkTalk Huawei HG633 router in the same room as the printer to give the WiFi signal a boost (it's not convenient to have to keep moving the printer through when I want to use it as a scanner).
I'm having issues with actually scanning pages to the PC over WiFi - I think it's because the WiFi signal off the Sagemcom router is weaker in the room we keep the printer in, so I think setting up an extender would help.
Would I be able to use the instructions in this thread for an HG633 + HG635 set up to do this with my Sagemcom and HG633?
1 REPLY 1
Message 1 of 2
Yes, but how do you want to physically connect the two together, as this will affect the configuration required.
