Slow on ethernet
daz45
Message 7 of 7
Hi need some help With my Internet speeds
It Started last night everything was working fine until then
I am on full fibre 500 I am still getting around 350Mbps on phone(Wifi)
But ethernet has dropped to 95Mbps never getting above 100Mbps
This is for all devices that are connected vis Ethernet and there are seven of them
I have tried disconnecting everyone except my pc and connecting straight to the Eo router
Edit: Also just tried connecting directly to modem on the wall and still getting the same speeds 95 Mbps.
Also my phone ia an Iphone 11 which Is capable of 877Mbps, so It seems the Wifi IS slow also
thanks
Darryn
6 REPLIES 6
Message 1 of 7
Excellent, Thanks for confirming.
Message 2 of 7
Yes thank you all working ok
Message 3 of 7
Hi @daz45
Just to confirm, is everything working ok now?
daz45
Message 4 of 7
It was Ethernet cable's please Ignore.
thanks
daz45
Message 5 of 7
Thanks for the reply
To connect to the modem yes, the one the engineer connected It with
All the cables are the same as they were when It was working up until last night.
Chris-TalkTalk
Message 6 of 7
Hi Darryn,
Are you using the ethernet cable supplied with the router?
