WiFi Extender Admin Logon
howarddiver
Message 4 of 4
I have a TalkTalk DHP-W610AV Wifi extender.
I'd like to set its wifi channel to 11 which is lightly used in my area.
Can I do this and keep it at 11?
I do not know the Extender's admin username or password.
Any info. would be much appreciatred.
Howard
3 REPLIES 3
Message 1 of 4
You're very welcome.
howarddiver
Message 2 of 4
Many thanks for the info. Keith.
Worked exactly as you said.
Howard
Message 3 of 4
Yes, you can. On some routers, it is easiest to first find out the extender's IP address from its show devices section & use that to connect to the extender. The admin password is on the rear of the extender unit & is unique to each unit.
