on 02-05-2022 09:54 AM
I am really struggling with broadband at our house. We get 10-18mbps download and ping c. 20ms, which isn't great, but workable. What really isn't working is the upload speed; it used to be just over 1mbps now it seems to be capped at 0.7mbps.
What possibly happens is that any sort of upload or backup blocks/congests all the bandwidth, so internet usage is not possible. This does impact stability.
Is there a way to improve this speed (can talktalk do it?)? Is there a minimum speed for upload (11.2 download is the contractual download minimum)?
Thank you, John
on 25-07-2022 07:10 AM
I'm glad to hear this and thanks for the update. I'm just sending you a short survey via a PM now.
on 23-07-2022 08:18 PM
The engineer arrived the next day (in heat wave) and fixed it. I think we are getting 1mbps now. Thanks for your help, John
on 19-07-2022 06:29 AM
How are you getting on? Did the engineer arrive after your last post?
on 18-07-2022 05:16 PM
BT openreach haven't arrived yet but the internet isn't working at all now.
on 14-07-2022 08:29 AM
Hi John
I have arranged the engineer visit for Monday 18/07 PM (1pm - 6pm)
on 13-07-2022 11:46 PM
@Chris-TalkTalk, yes please schedule the engineer. All guidance has been followed as instructed. If there are any other steps you think I should follow please let me know (including testing with multiple devices and two ethernet cables directly to two different routers with two different splitters). John
on 13-07-2022 10:42 AM
Thanks for answering the security questions, could you just confirm that you accept potential engineer charges and we'll book the engineer visit for you
on 13-07-2022 10:38 AM
Thanks completed the DM link.
Available Monday pm, Tuesday am/pm, not Wednesday/Thursday, Friday am/pm
on 13-07-2022 07:15 AM
Hi johnttjohn,
Openreach don't guarantee upstream speeds but line test is picking up a potential issue and there appear to have been some disconnections over the last few days so we can arrange an engineer visit
If you'd like us to arrange an engineer visit can you confirm:
on 12-07-2022 09:43 PM
@Anonymous @Karl-TalkTalk , new filter and no difference. I think we need an engineer. Thank you John
on 11-07-2022 06:58 AM
I've re-run the line test now which is still detecting a potential fault towards the property. Did you also change the cables and microfilter? If all testing has been completed at the test socket with the new router then the next step will be to arrange an engineer visit to the property.
on 08-07-2022 10:11 PM
Hi @Anonymous , @Karl-TalkTalk , I hope you are well. Just to update you that unfortunately the router hasnt helped. Still getting an upload speed of barley over 0.7mbps (this evening upload speed is not breaching 12mbps). Set up is the same with test plug. Can you retest the line? Many thanks, John
on 09-06-2022 08:02 AM
Just checking back in to see if the router has arrived and if there has been any improvement?
on 06-06-2022 07:30 AM
Hi John
Sorry for the delay, the router is on the way.
on 02-06-2022 03:21 PM
@Anonymous @Yes please. Let's try that. We haven't tested another router. Joh
on 31-05-2022 07:26 AM
Thanks for confirming. Have you ever tested with a different make and model of router? If not then I think we should send one for testing to see how the speed compares. We would also send a router returns bag so that one of the routers can be returned.
on 31-05-2022 07:19 AM
@Anonymous , good morning. Yes it is still in the test socket. Thank you, John
on 31-05-2022 06:33 AM
Thank you. I've re-checked the connection stats now and I can see that the sync speed started to increase and then dropped again. Is the router still connected to the test socket at the moment?
on 30-05-2022 04:30 PM
@Chris-TalkTalk - bump!
on 27-05-2022 11:20 AM
OK thanks 🙂
