WiFi coverage through TalkTalk WiFi Extender is not reliable. Should I ditch this extender and get
SKMBAILIE
Message 4 of 4
WiFi coverage through TalkTalk WiFi Extender is not reliable. Should I ditch this extender and get another brand?
3 REPLIES 3
Message 1 of 4
Thanks for your help @KeithFrench
Message 2 of 4
The correct way to extend a Sagemcom FAST5364 or 5464 router is via a Sagemcom FAST266 WiFi Booster, which forms a mesh network with the router.
Message 3 of 4
Is this the TalkTalk WiFi Extender? If so it does have a bug in it where the throughput drops to next to nothing on the WiFi, but the Ethernet connection remains fine. What make/model of router do you have?
