WiFi turned off
Kerr78
Message 3 of 3
WiFi is turned off
Message 1 of 3
Morning Kerr,
How are you getting on?
Message 2 of 3
Have you tried a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
See if this resolves the issue. If not then we can issue a replacement router.
