Wifi hub issues
96 REPLIES 96
I have just installed the TalkTalk Wifi hub. I was previously having problems with dropping connections, very slow speeds, and constant buffering on  my TV, after installing a new free router from TalkTalk - after a long support call, they decided the router was faulty and offered to replace it but also advised me to buy the Wifi Hub as an upgrade. So I've paid for the hub but still appearing to be having the same problems that I had with the faulty router. There was mention of a stablisation period - is this applicable if you are already a TalkTalk broadband customer and just install a new router, or is it only relevant for people who have newly moved to TalkTalk?
Hi scooper1401
  • Name
  • Telephone number
  • Alternative contact number
I  have updated my profile.
I have checked my broadband speed regularly at  different times of day and am still getting only between less than 1 and just over 2 mbps, in an area where up to 6.2 mbps should be available on basic copper line broadband.
Hi scooper1401
Apologies, there are no details showing in your Community Profile. Did you click on the save changes button on the bottom of the page?
I updated my details using the wizard - as it opened separately I didn't realise I would still have to use the Save button on the main page. I will try again!
Should be OK now....
Hi scooper1401
I have optimised your connection and the sync speed has increased slightly. Is your router currently connected at the test socket?
What do you mean by the test socket? The router is connected to the main phone socket for the house, as it was when a few years ago a TalkTalk engineer came out to set up my TV for me, so I assume it's all correctly set up.
Hi scooper1401
Would it be possible to post a photo of your master socket?
Hi - I tried to attach a photo but got an error message
The file 20191203_084708_resized.jpg does not have a valid extension for an attachment and has been removed. pdf,doc,ppt,docx,pptx,xlsx,psd,gz,zip,svg,.txt are the valid extensions.
Is it not possible to attach a jpg?
Hi scooper1401
Is the master socket split across the middle so the lower section can be removed?
This help page provides further information on test socket testing Your guide to master sockets
It's a Non NTE
Another thing I've noticed is that my land line phone has become very noisy. It's normally plugged into an extension socket, but I have tried plugging it directly into the master socket (well, using a microfilter) and it's still noisy.
Hi scooper1401
I've completed a line test which is detecting a possible fault.
Is the noise still present if you test with a corded handset at the master socket, with the router removed from the line?
I can then escalate this over to Openreach for investigation.
Yes, this is what I tried and the noise was still there. But is there a chance it could be a faulty phone and this is just coincidence? I don't want to end up with OpenReach telling me it's my phone that's faulty and not their line, then charging me.
Unfortunately I don't have another phone so cannot test for this possibility.
Also, it it's a faulty line, why was I told it was a faulty router and persuaded to buy another one?
Hi scooper1401
Would it be possible to test your phone on a different line to see if works ok there? This will rule out any possible issues with the handset.
I don't think so. My neighbours are all out at work all day and in any case I don't really know any of them well enough to ask them this sort of favour.
But if your own tests are indicating a possible fault, wouldn't this be sufficient grounds to ask OpenReach to do some testing anyway, never mind any possible issues with my hand set?
I will be off line for a couple of hours now
Hi scooper1401
Ok, are you happy for me to raise this fault straight over to Openreach for investigation?
