Will I need to change my Router in to Modem Mode?
KarenInAccounts
Message 4 of 4
Good afternoon.
I have deadzones in my house and I'm looking to upgrade my router to a ASUS DSL-AC88U AC3100 as this has multi directional antennae so hoping that can beam me a good signal. Will I be able to unplug my current TALKTALK router and then just plug the cables in to my Asus and it be fine? Or will I need to put my TALKTALK router in to Modem Mode and connect the new router to it?
3 REPLIES 3
Message 1 of 4
Hi KarenInAccounts
Do you still need help with this?
Message 2 of 4
Hi KarenInAccounts
I can see that @KeithFrench has offered to help. Keith provides really great advice on improving wireless performance.
Message 3 of 4
Have you investigated the problem at all, throwing money at another router might solve it, but then again it might not. I offer free help and that may well resolve it, depending on the cause of the reception issues.
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
