on 12-11-2022 12:17 PM
hi,
I am having problems with my router not working with wi-fi it works with cables but we cannot connect with laptop by wi-fi or mobile phone with wi-fi
we have turned off power and left router off fo 30 minutes but still not working when power is turned back on to router .it is a hg633 wireless light is on but still not working even standing next to router.
we are on fibre 65
any thing else we can do
on 21-11-2022 09:51 AM
on 21-11-2022 09:49 AM
Hi @Jaygee47
You're very welcome.
on 21-11-2022 09:46 AM
Hi Jaygee47
I'm so glad to hear this, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
on 21-11-2022 09:38 AM
Hi Keith,Michelle,Debbie,
Thank you all for your help ,new router received and we now have wifi back working ,just in time for weekend when we have teenage grandaughter staying. Would have been unbearable with wifi not working.
once again thank you all for your help it was very much appreciated.
Jaygee47
on 16-11-2022 01:19 PM
Hi Jaygee47
on 16-11-2022 01:14 PM
hi michelle,
Yes please, if you could send a replacement router which hopefully will sort out my problems
regards
jaygee47
on 15-11-2022 01:01 PM
Thanks @KeithFrench 🙂
We can send a replacement router for testing, however we no longer provide HG633's so this would be one of our Wifi Hubs. Would this be ok?
on 15-11-2022 12:57 PM
I have been doing some diagnostics via PMs with this one. There is no WiFi SSIDs being broadcast from this HG633, despite being enabled in the router's UI. I can only assume it is faulty.
on 14-11-2022 09:22 AM
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed in), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so that I can find it easily.
on 13-11-2022 11:22 PM
hi Keith,
thanks for offering to help,
Could you please send out the guide for fault finding
regards
jaygee47
on 12-11-2022 01:06 PM
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
