on 09-11-2022 11:17 AM
Moved house and had our connection set up on Monday (7/11/22) - since then the internet has been patchy but mostly functional.
But since last night we’ve had nothing at all, despite a constant white light on the router. Tried restarting and resetting everything, but no luck.
I’ve tried calling and troubleshooting, and got nowhere. TalkTalk have run countless “line tests” and found a fault, but no updates over the last few days.
Fault ref number if helpful - REP-12084898
on 21-11-2022 10:41 AM
You do not need to swap the routers if all is well, but it's entirely up to you if you want to send back the old or new one. Speeds will differ at your new address as each home will have a different speed rating based on the distance from the exchange and the product used.
I am glad to hear that the connection has however been more stable for you.
on 21-11-2022 10:35 AM
Thanks so much for all your help - we’ve managed to both be online this past week, and the connection is a lot more stable.
We didn’t swap routers in the end - is it worth still trying this / do we need to return the new one?
It’s certainly slower than what we’re used to, but when we moved we had to downgrade from Fibre due to it apparently not being available at our new address, so this is likely the issue?
on 15-11-2022 08:57 AM
I've checked the courier, delivery was attempted on the 12th but failed, currently at the local depot awaiting re-delivery.
i'll drop you a PM with the Yodel tracking Number.
on 15-11-2022 08:44 AM
Hi - thanks for checking, still no change unfortunately.
We’re still waiting on the new router for testing, but no sign. Is there a way to track it?
on 15-11-2022 06:31 AM
Just checking in to see how you're getting on?
on 11-11-2022 10:53 AM
Hi bmlr95
Please can you send me a Private Message with the serial number from the back of the new router?
on 11-11-2022 10:50 AM
Yes, works and is stable if it’s just me. When she connects too, it kills the connection. We tried to vice versa again - me turning off my WiFi, her connecting alone - and she got a connection, but a very slow one.
Not sure if it makes any difference but mine is Apple, her’s is Windows.
on 11-11-2022 10:40 AM
Ok, if you only connect your laptop is the connection/speed ok? (Until the 2nd laptop is connected)
on 11-11-2022 10:37 AM
Sorry Debbie, we don’t have a way to connect her laptop with a wired connection - it doesn’t have an Ethernet port.
We reset the IP configuration on her laptop and we can now both get a connection, but it’s so slow it’s often not loading sites at all.
on 11-11-2022 10:30 AM
Hi bmlr95
So just to confirm, if you connect your partners laptop wired is the connection ok?
on 11-11-2022 10:27 AM
Hi both - just as an update, we had consistent internet connection yesterday still using the old router.
The only difference was that my partner was in the office all day. Now she’s home again, it’s not working. We ran a few tests - if she turns her Wi-Fi off on her laptop, I can get a connection on mine. But it doesn’t seem to work vice versa.
Unusual, I know! Any ideas?
on 10-11-2022 10:42 AM
Hi bmlr95
Thank you 🙂
on 10-11-2022 10:36 AM
Thanks so much Debbie and Chris for your help - will keep this thread updated, fingers crossed! 🤞
on 10-11-2022 10:35 AM
Hi bmlr95
Thanks for the Private Message 🙂
on 10-11-2022 10:15 AM
Hi bmlr95
Please can you send me a Private Message to confirm the name on the account, I can then send the router.
on 10-11-2022 10:12 AM
Thanks Debbie, that would be great.
As an update - our internet kicked back in again yesterday evening, and has been consistent-ish since, with a few dips.
on 10-11-2022 06:45 AM
Hi bmlr95
I can send a replacement router to the address linked to the telephone number in your Community Profile, will this be ok?
on 09-11-2022 03:34 PM
Sorry, this is the only one we have. What’s the best way to send one?
on 09-11-2022 03:32 PM
Do you have another router that you can test with? If not then we can arrange to send one
on 09-11-2022 03:27 PM
Correct. We don’t have any wired devices, but several connected to the Wi-Fi (TV, two smartphones, two laptops) - all of them connect to the router, but aren’t getting any internet.
