Solid white light on the router but no internet connection
bmlr95
Message 28 of 28
Moved house and had our connection set up on Monday (7/11/22) - since then the internet has been patchy but mostly functional.
But since last night we’ve had nothing at all, despite a constant white light on the router. Tried restarting and resetting everything, but no luck.
I’ve tried calling and troubleshooting, and got nowhere. TalkTalk have run countless “line tests” and found a fault, but no updates over the last few days.
Fault ref number if helpful - REP-12084898
27 REPLIES 27
Message 21 of 28
And all devices are unable to connect to the internet, both wired and wireless?
Message 22 of 28
Correct.
Message 23 of 28
Just to connfirm, your internet connection was working fine for about an hour but now it's not working at all but the light on the router is still white?
Message 24 of 28
Thanks Chris - did that and it worked for about an hour. Now back down again…
Message 25 of 28
OK thanks. Could you switch your router off and leave it off for at least 30 minutes then switch back on and retest. Please let us know how you get on
Message 26 of 28
Thanks Chris - we don't use the landline so don't have a phone to hand to test, sorry!
Chris-TalkTalk
Message 27 of 28
Hi bmlr95,
I'm sorry to hear that you're experiencing problems with your service. Are you experiencing any problems with your telephone service? Is there a dial tone? Any noise on the line?
