on 23-01-2025 08:15 PM
I use a VPN connection (with OpenVPN) provided by my University. Unfortunately, this get blocked by my TalkTalk router. I can connect but the speed is incredibly low. The same problem is not there when I use other WiFi networks.
Can you help?
on 02-04-2025 01:15 PM
Hi Karl, no I have never done it, but I can google it...
on 28-03-2025 10:08 AM
Do you know how to perform a trace route ?
on 28-03-2025 10:03 AM
Correct. The VPN connects but it runs very very slow.
on 28-03-2025 07:50 AM
Can I just clarify, is the VPN still connecting , but running slow, as previously, or just not connecting at all now ?
on 27-03-2025 03:47 PM
nothing to do. I turned it off, waited 30 seconds and switch it on again.
The VPN is unfortunately still not working. 😞
on 27-03-2025 03:07 PM
The MTU is a setting on the router but we don't usually change it. Could you try rebooting the router and then retest. Please let us know how you get on
on 27-03-2025 02:52 PM
I have read online that the problem might be due to the size of the MTU allowed by the DSL. Is there a way for you to change this?
on 27-03-2025 02:44 PM
nothing has changed 😞 The VPN is still not working ...
PS: I have just tried to use it on from mobile data (using my phone as "hotspot" ) and in this case, it works without problems instead.
on 27-03-2025 01:44 PM
I've initiated the firmware update, it should complete in a few minutes. Please don't switch off your router
on 27-03-2025 01:40 PM
OK I'll do it now
on 27-03-2025 01:38 PM
yes! thank you
on 27-03-2025 01:37 PM
Is it OK to do it now?
on 27-03-2025 12:13 PM
Can you please wait 30 minutes?
on 27-03-2025 12:12 PM
Is it OK to do it now, your internet connection might be down for a short time?
on 27-03-2025 11:18 AM
ok! thanks
on 26-03-2025 01:41 PM
Hi Chiara,
OK, we could try changing the router firmware to an older version, would you like to give this a try?
on 25-03-2025 02:41 PM
Hi Chiara,
I'll see if there's further that we can do. Leave it with me and I'll get back to you
on 24-03-2025 06:34 PM
Hello Karl,
unfortunately the new modem did not solve the problem of the VPN. I believe it could be firewall related maybe?
Best,
Chiara
on 11-03-2025 10:24 AM
You're Welcome 🙂
on 11-03-2025 10:22 AM
Thank you very much Karl!
Chiara
