on 23-01-2025 08:15 PM
I use a VPN connection (with OpenVPN) provided by my University. Unfortunately, this get blocked by my TalkTalk router. I can connect but the speed is incredibly low. The same problem is not there when I use other WiFi networks.
Can you help?
on 11-03-2025 10:15 AM
That's ordered for you and should be with you within the next 48hrs.
on 11-03-2025 10:08 AM
then yes, let's try that 🙂
on 11-03-2025 09:40 AM
Yes it is 🙂
on 11-03-2025 09:39 AM
Is this free?
Not switching off, I meant sending out a new router to you to test to rule out any hardware fault.
on 11-03-2025 09:34 AM
Hi Karl,
thanks. Do you mean switching off, wait a minute and turning it on again? Already done!
However, what I do not get is : nothing happened, it was working one day and not working the following one. And this happened last month already!
Since nothing is changing/happening to the modem, how can it be a fault?
on 11-03-2025 07:12 AM
Would you like to swap out the router to rule out a fault with that ?
on 10-03-2025 03:25 PM
I think the problem is TalkTalk, as I can connect and use the VPN when using my phone data as hotspot (or using any other internet connection)
on 10-03-2025 03:23 PM
Have you tried speaking to your University IT department about the issue?
on 10-03-2025 01:35 PM
I contacted TalkTalk using the chatbot. I talked to two different operators and they made me run a series of tests (including turning off and on the modem)
on 10-03-2025 01:31 PM
Thanks, could you explain what you mean by client support
on 10-03-2025 09:13 AM
Hello, yes it is so slow that it is practically impossible to use. I had this problem a month ago, after huge pain and discussion with the client support it went magically away and now it is back.
on 10-03-2025 07:44 AM
Hi KiaraSpin,
How has it been over the weekend, is the VPN still running slowly?
on 07-03-2025 04:01 PM
I have re-escalated this for you, but please bear in mind that the support team probably won't pick this up before Monday now.
on 07-03-2025 03:41 PM
Hello everybody,
the problem seems to be back. I have done literally nothing new to my WiFi, but now, once again the VPN is incredibly slow that one cannot navigate. Could I get support?
Thank you
on 27-01-2025 09:31 AM
Thanks for confirming. Is the VPN also working too?
on 27-01-2025 09:25 AM
Yes. It is working now.
on 27-01-2025 07:40 AM
I'm sorry for the delay. The line is showing in sync and connected. Have you now been able to connect ok since your last post?
on 26-01-2025 02:16 PM
Wait until tomorrow, the support team aren't online at weekends.
on 26-01-2025 12:20 PM
