speed problem
Lesman
Whizz Kid
Message 335 of 335
Hello.
I have a contract for a Fiber35 package. The download speed is about 27 Mbps and the upload speed is about 6 Mbps. On February 23, the speed suddenly dropped to about 13 Mbps to the router and 11 Mbps to the PC. A line check showed a problem. On March 2, an engineer arrived. After his visit, the speeds did not change much and the line test continued to show the problem. After about three weeks, the line test shows that everything is fine, but the speeds to the router are 18 Mbps and to the computer 15 to 16 Mbps. This situation continues to this day. I don't understand why the speeds can't go back to normal as they were according to the subscription, and it's been over a month! My neighbor has Internet on the same network and still has normal speeds and we are connected the same way!! I do not understand! I'm still using the original router and cables I received when I first connected, and why is the speed difference 2 to 3 Mbps? Please explain this problem to me and help me get back to normal.
334 REPLIES 334
Anonymous User
Message 281 of 335
I'm really sorry to hear this. I've re-run the line test now which has detected a possible fault. Just before we pass this over, could you confirm if the voice service is ok with no noise on the line please?
Message 282 of 335
To clarify the problem information: August 28 The current download speed is about 4 Mbps and upload speed is about 7 Mbps. I don't understand why the upload speed is higher than the download speed?
Regards  Les
Message 283 of 335
To clarify the problem information: The current download speed is about 4 Mbps and upload speed is about 7 Mbps. I don't understand why the upload speed is higher than the download speed?
Regards  Les
Message 284 of 335
Most staff are away till Tuesday, @Lesman.
Re-escalated for their attention.
Message 285 of 335
Hello Michelle
On Friday, August 25, the internet connection dropped twice and the speed dropped from 29 Mbps to 21 Mbps. On Saturday, August 28, the speed returned to about 29 Mbps. Sunday, August 27 - the internet keeps breaking down, the speed drops to about 8 Mbps. I did a line test and got a message that there is a problem with the line. I don't count how many times this year this problem repeats itself, but it's getting annoying. Can't you fix this line once and for good so that these problems don't happen again?
Restarting the router does not change the situation.
Regards   Les
Anonymous User
Message 286 of 335
Good afternoon,
Thanks for confirming and please let us know if you do need any assistance.
Message 287 of 335
Hello Michelle
On Friday, I turned off and on the router and the speed reached about 29 Mbps. Over the weekend I was controlling speed. On Saturday, the speed reached 30 - 31 Mbps and has remained so to this day. I took the measurement about 15 minutes ago. I hope this will be the end of the problems. I think the limit of problems has already been exhausted.
Thank you for your help.
Regards  Les
Anonymous User
Message 288 of 335
How are you getting on?
AllyM
Message 289 of 335
@Comstock1977 ,
You appeared to be complaining that the speed you were getting was lower than the guaranteed minimum you had been quoted (by means which you refuse to divulge), but this figure was different from what support staff could see on their systems, meaning that the help they were able to offer you was limited.
There is a complaints process outlined on TalkTalk's website and, as I said, the CEOs contact details are freely available so the OP has always had that option.
Also, I'm not sure what a "none employee" is. My best guess is that you mean "non-employee".
Message 290 of 335
Hi Ally.
My compensation was decided by an independant body. An arbiter. Talk Talk agreed & The apology and compo didnt state i was misinformed, either. You appear to be.
Also you do not know the entirety of my complaint - because, i refuse to divulge outside of Talk Talk, and it has nothing to do with you as a none employee.
As this user is experiencing what i was offered, from this forum and call centre:-
Im offering this user an option, instead of a wheel of confusion and pretty poor advice here.
The test socket tests.
AllyM
Message 291 of 335
@Comstock1977 ,
Firstly, the OP can get contact details for the CEOs office quite easily using any search engine. It's not a national secret.
Secondly, I think your own issue was quite different. As I recall, there was never anything wrong with your line. You never actually got the speed increased because you are getting the fastest speed your line can physically support. Your issue was that you were previously mis-informed that your line was capable of faster speeds (although you refused to reveal who informed you of that) and you got (very generous) compensation for that administrative error.
Message 292 of 335
Hi Lesman
Whilst youre waiting for a fix, every 3 months, would you like to contact details of the directors office, to get maybe some compensation?
This isnt spam, i did this in 21/22.
Let me know, im still with talk talk and try to help people experiencing similar to what happened to me -test sockets, new routers, open reach and calls to the call centre, oh and line tests saying everything is fine? Sound familiar?
Let me know
Message 293 of 335
try the power down and see how it goes over the weekend.
If no improvement then an engineer may be required.
Message 294 of 335
Sorry, I was away from home. When I got back, I did as you said. The speed increased to about 27 Mbps, and today it is about 28 Mbps. I was supposed to do that earlier, but after two or three days the speed dropped to around 20 Mbps. Should I now repeat turn off - turn on the router?
Les
Message 295 of 335
The profile is set correctly at 40, can you power off the router for 30 minutes so I can see if the sync rate increases, if not I'll need to pull the DLM logs for the last couple of days to check for errors and pass this across to openreach.
Message 296 of 335
For the last two days the speed was around 30 Mbps, today it dropped to around 21 Mbps. The situation repeats itself - after repair, 2 to 3 days are good and return to the old situation.
Regards.  Les
Anonymous User
Message 297 of 335
Just checking back in to see how your connection has been?
Message 298 of 335
Hi Lesman
Openreach have now closed the fault as resolved.
Is everything working ok now?
Message 299 of 335
Hi Lesman
This fault is still with Openreach, there are no additional updates at the moment, sorry.
Message 300 of 335
Hi Lesman
I can see that this fault has been passed to Openreach and is under investigation with a line engineer.
We will continue to monitor for additional updates from Openreach.
Anonymous User
