vpn connection issue
Graham_T
Message 3 of 3
I'm no longer able to access my work vpn from home and have been told my router is the issue and needs its firware updating to allow Generic Routing Encapsulation
my router is TALKTALK Wi-Fi Hub FAST 5364-3.T8 can this be done and how?
Message 1 of 3
I'm having difficulty connecting to your router.  Can you try a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
When back online we can retry.
Message 2 of 3
Assuming this router is running firmware ending in 136, then yes, this is the issue.
I have asked one of TalkTalk's support to pick your thread up and change the firmware (you cannot do it yourself).
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
Anonymous User
