on 06-09-2023 02:54 PM - last edited on 26-09-2023 10:47 PM by Gondola
Help
I have a new PC and PC World are trying to set up my talktalk e-mail in outlook and they just cannot get it to connect to the server, they have been trying for a week without success. The Webmail works fine and my phone works fine, I have re set the password but nothing works.
Any help is greatly appreciated.
on 06-09-2023 03:38 PM
Outlook supports secure mail and to update go via the Advanced setup settings of an email profile, as in this example for Windows 10 / 11
At that point on your device you ought to see the Outlook setup to enter the TalkTalk Mail server settings: NB All talktalk domains use the exact same IMAP secure settings.
Supported Outlook settings for IMAP email accounts are:
| Account Type | IMAP secure |
| Username | Full TalkTalk email address |
| Password | TalkTalk email password |
| Incoming mail server | mail.talktalk.net |
| Incoming Port (IMAP) | 993 |
| Incoming Connection Security | SSL/TLS |
| Outgoing mail server | smtp.talktalk.net |
| Outgoing Port | 587 |
| Outgoing Connection Security | STARTTLS |
| My Outgoing Server Requires Authentication | Yes |
| Authentication Method | Normal Password (Not SPA) |
For a definitive check of settings take screenshots of the incoming and outgoing server settings, image edit to obscure the first part of the email address and upload here using the Camera icon (desktop browser) or Picture icon (mobile browser) above this reply area.
The above settings will save and connect to the server.
Gondola Community Star 2017-2024
Like below to appreciate my post . . . Mark as solved Accept as Solution
