Talktalk hub constantly resetting 2.4ghz channel to 1
8 REPLIES 8
Hi, I see that there are other posts with the same issue. I have repeatedly changed the channel on my talktalk hub to 6 as this is the only channel not in use in my vicinity. Everything works great for a while but then my WiFi security cameras begin disconnecting. When I check the WiFi channel, it has returned to 1 (which is the most congested).
I have changed the channel dozens of times now but after a few hours the hub as changed it back to channel 1.
Can you help me sort this out as it is ridiculous.
Hi @gail123 your post has been flagged for assistance and you should hear during tomorrow.
Short answer could well be not currently possible, but let's hope I am wrong, as usual and you get a good solution tomorrow.
Hi gail123
I'm just looking into this further and I will post back on this thread as soon as I receive further information.
Hi Debbie
Is there any update on this as it has been over a month now with no reply.
The router is still changing the WiFi channel randomly which is causing me problems so I would appreciate some feedback.
Hi @gail123 I have a feeling a solution has been found and am sure @OCE_Debbie will get back to you tomorrow.
Hi @gail123 oooops sorry got my days wrong, should have said Monday.
Hi gail123
Apologies for the delay.
Our performance monitoring tool will only change channels when interference is detected.  It will learn about each device that is connected over time.
However our Products Team have advised if you are experiencing issues and would prefer to select your own wireless channels then we can arrange for Wi-Fi optimisation technology to be switched off on your line.
Hi Debbie,
If you could arrange for the monitoring tool to be switched off, that would be great.
Many Thanks
Gail
Hi gail123
Optimisation is now turned off for your connection.
