printer not connecting
3 REPLIES 3
Visitor
my HP printer is not connecting to my talk talk router / hub. a wireless network test suggests that the MAC address filtering might be enabled but it is not. troubleshooting via the printer just says no connection and wirless wizard says the same. has anyone any ideas?
Hi @sita26 have you tried Split your router's SSID (wireless network name) ?
your post has been flagged for assistance and you should hear back soon.
In the meantime please check your community profile and add your landline phone number which is used to identify your account. Click avatar top right corner then settings, then wizard. Please don't post personal details here for security reasons
Hi sita26
I had a similar issue and I fixed mine by splitting the SSID's and connecting using the 2ghz. Have you tried this?
