on 21-05-2024 02:32 PM
In March I had an issue with 2.4G Wifi signal dropping out and the issue was resolved at the time by TT who switched the wifi optimisation off.
This issue has now started again and the only way I can get 2.4G is by re-booting the router but this only lasts a few days until it happens again.
Can you confirm that WIFI optimisation is still switched off? If so how can this issue be resolved.
on 22-05-2024 07:28 AM
Hi Bostin1
I'm unable to connect to your router. Please can you send me the serial number from the back of your router by Private Message?
Just to add, we are no longer able to switch off WIFI optimisation.
on 21-05-2024 10:00 PM
Of course, as a customer myself, I have no influence on TalkTalk policy, I am just the messenger here.
on 21-05-2024 05:49 PM
Hi Keith,
Thank you for your feedback I will wait for a response.
Please see below the original response in March which cured the issue. I did have a separate problem with broadband speed in April (1-2MB download) TT arranged for Openreach to check the lines etc. No issues were found by them, apparently (as I understood) from the engineer the issue was with the speed which had been turned down at source, it was reset and things have been OK up until the past few days.
Speed is OK only 2.4G.
on 05-03-2024 09:39 AM
Hi Bostin1
I have switched the WIFI optimisation off, please let us know how the connection compares.
on 21-05-2024 03:16 PM
The current policy is to not disable Wi-Fi optimisation, although I hadn't heard that any customers who already had it disabled would find it suddenly enabled again. Of course, a factory reset of the router will always re-enable WiFi Optimisation.
I have asked one of TalkTalk's support to pick your thread up and adviser you.
