2.4GHz chnnel Optimisation
YaphamRoad1
Message 4 of 4
How do you turn the channel optimisation feature off on the router?   One of our older devices keeps losing connection to the WIFI, reseting the channel on the router only works temporarily.
I have one of the new TalkTalk Wi-Fi Hub 2 routers.
3 REPLIES 3
Message 1 of 4
Hi YaphamRoad1
Do you still need help with this?
Message 2 of 4
Hi YaphamRoad1
Please can you add your name and TalkTalk landline number to your Community Profile, I can then switch the WIFI optimisation off for you.
Gliwmaeden2
Message 3 of 4
You don't, @YaphamRoad1.
It has to be done by staff, so make sure that you leave the router on for them.
They'll reply after the weekend.
